-   Tools (http://www.diychatroom.com/f29/)
-   -   Compressor to run roofing nailer. (http://www.diychatroom.com/f29/compressor-run-roofing-nailer-114411/)
slimjim 08-17-2011 10:15 PM
Would this air compressor be sufficient to run a roofing coil nailer rated at 2.5CFM @ 90 psi ? Going to be shingling my roof soon, which is 52 feet by 22 feet.
3.4 Gallon
4.9 CFM @ 40 PSI
3.6 CFM @ 90 PSI
2 HP
Max. pressure: 125 PSI
110V/60 Hz electric motor
Oil lubricated direct drive pump is quieter than oil-free compressors
Includes: regulator and dual gauges
Suitable for light duty applications and general household use
ASME safety valve with thermal protector, pressure gauge, quick coupler
Motor with copper wiring, rust-resistant powder coat finish
Max. motor output: 1200W (40W)
No load speed: 3,400 RPM
Bore and stroke: 48 x 38 mm
http://www.princessauto.com/workshop...air-compressor
firehawkmph 08-17-2011 10:56 PM
Slim,
that compressor should work fine. Air nailers don't suck up near as much air as continuous running tools like grinders.
Mike Hawkins:)
