Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-08-2010, 08:35 AM   #1
compressor problems
I have a porter cable cf 2400 compressor in my shop that started to act up recently. After it builds up to pressure appr. 140lbs it will kick off but the pressure switch continues to bleed off pressure until it kicks back on. I took the switch apart and could find nothing wrong with it. I then replaced the entire pressure switch with a new one, plugged it back in and it did the exact same thing. How is this possible? Please help
TOMF is offline   Reply With Quote
Old 02-08-2010, 01:11 PM   #2
Master General ReEngineer
Bondo's Avatar
compressor problems
Ayuh,... The Fitting, In the tank, where the pumps output line connects,... Is a Check-valve...
Take that valve out,+ Clean it,... If that don't work, replace it...
Old 02-08-2010, 02:21 PM   #3
compressor problems
where did you get replacement parts for your compressor?
GamblinFool is offline   Reply With Quote
Old 02-08-2010, 03:49 PM   #4
Super Moderator
compressor problems
Tom-F---I have had this problem with Campell-Hausfield compressors(Rigid)
If it's the same set up your reed valves are worn out. Remove the head-there is a flat spring steel plate under the head. That's it.
If the reeds fail completely--the piston and cylinder walls will be damaged.--Mike--
Old 02-09-2010, 11:51 AM   #5
compressor problems
Thanks man that was it, it now works great Thanks a million
Old 02-09-2010, 11:53 AM   #6
compressor problems
http://www.ereplacementparts.com/por...rts-c-129.html
sent em right to me
Old 02-09-2010, 11:53 AM   #7
compressor problems
It was the check valve but thanks mike
Old 02-09-2010, 11:57 AM   #8
compressor problems
Originally Posted by TOMF View Post
Go Figure... Just like there is an app for everything, there is a web page for everything!
