Compressor Adequate For Framing Nailer - Tools - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 12:14 PM   #1
Rewards Points: 518
Compressor adequate for framing nailer
I have a Campbell Hausfeld 8 gallon compressor with these specs:
  • Air compressor has a tank capacity of 8 gallons, and delivers a maximum pressure of 200 psi
  • Has a 1.3 hp motor, and delivers 3.7 scfm at 90 psi
I have used a brad nailer and 15ga finish nailer without issue however I want to try a framing nailer on my next project. Will my compressor be adequate? I'm not sure what depth I'll be shooting, whatever works for 2x4's and 2x6's, and a couple of header pieces.
n0c7 is offline   Reply With Quote
Old 02-25-2013, 04:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,.... Nailers ain't to much of an Air Hog, ya oughta be just Fine..
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
n0c7 (02-25-2013)
Old 02-25-2013, 04:40 PM   #3
Rewards Points: 13,960
I use a smaller one that that all the time with no issues.
n0c7 (02-25-2013)
Old 02-25-2013, 06:53 PM   #4
Rewards Points: 1,016
I sometimes use a smaller pancake compressor. If I get going fast, it can get behind. Helps me to pace myself.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
n0c7 (02-25-2013)
Old 02-25-2013, 08:40 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
your tank size is fine its the cfm rating thats really important on a small compressor. if the motor cant refill the tank quick enough to keep up wit the gun your going to not only have to finish the nails by hand but also burn out the compressor
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
n0c7 (02-25-2013)
Old 02-25-2013, 10:59 PM   #6
Rewards Points: 518
I'm looking at a Bostitch stick nailer that is asking for 3.9 scfm at 90 PSI. Since my compressor is only rated for 3.7 scfm at 90 PSI, is that 0.2 difference going to really matter? By the sounds of what you're all saying, I'm assuming not...
Old 02-26-2013, 01:06 AM   #7
Remodeler
Rewards Points: 330
You have more than enough compressor for a framing gun.
You don't normally fire nails in rapid succession anyway, usually you just shoot a couple nails and have to reposition the gun. In those few seconds a small tank will recover pretty quickly. Worst case, you may have to slow down and give the compressor a couple extra seconds to recover when doing something more demanding like nailing together a large header where you are able to fire several nails quickly.
Your psi spec is a little confusing, 200 psi is more than most two stage compressors will do. I have never seen a small portable that would handle that kind of pressure.
iamrfixit is offline   Reply With Quote
Old 02-26-2013, 05:43 AM   #8
DIY staff
Rewards Points: 7,174
Yep---3.9 is just fine for a nailer like yours----
Old 02-26-2013, 06:54 PM   #9
i run my framing guns at 110 psi with no issue. .its needed for sinking nails in egineered lumber
as for psi ratings over 200.. makita, max air and a couple other companys now make high pressure guns and compressors.. the makita framer runs at 260. not only is it more powerful but its much smaller.. their relatively new to north america but have been in use in japan for some time.. you can see them online at the american home depot webpage
Old 02-26-2013, 07:55 PM   #10
Remodeler
Rewards Points: 330
Guess I haven't stayed up on the latest and greatest as well as I used to.
Interesting technology but it comes with a serious price tag. I don't have many problems with my 120 psi pneumatics, but don't often work with engineered lumber. The compact size of the guns and the quieter compressor would be a real bonus though.
Reading some reviews it looks like maybe they still have a ways to go before I'm willing to lay down that kind of dough.
Old 02-26-2013, 08:37 PM   #11
the tech is there i know a few guys that have gotten to try demos of them.. they said the makita gear is amazing. ive seen them first hand just havent used it.. the price is the killer.. until everyone is making high pressure though you wont see the price drop
Old 02-27-2013, 09:12 AM   #12
Rewards Points: 518
It's advertised as 200psi max, but it's regulated at 125 PSI.
Old 02-27-2013, 09:12 AM   #13
Rewards Points: 518
Mine's 3.7... Think that small 0.2 will make a difference?
Old 02-27-2013, 03:29 PM   #14
as long as your not running more than one gun off it youll be fine
Old 02-28-2013, 03:12 PM   #15
I was worried about this too a while back I now have almost an identical compressor to you (mine's 6 gal) and I used a framing nailer with it. I litereally have not had one single issue doing this with a pancake compressor. Once I was doing a lot of nailing rapidly, I saw a nail went in only half way because I had depleted the compressor. I grabbed my hammer and finished it, by the time I put the hammer down I was good to go again. I'm building a small house with this so it just goes to show what you can pull off with it. If I was a professional I'd spend the money for a better one, but for $180 new this thing fits my needs.
ryan112ryan is offline   Reply With Quote
The Following User Says Thank You to ryan112ryan For This Useful Post:
oh'mike (02-28-2013)
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 01:04 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 03:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
