Compound Miter Saw Wont Shut Off - Tools - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 07:33 PM   #1
Compound miter saw wont shut off
My compound miter saw wont stop. I have to unplug it to make it stop and plug in to start. Can anyone give me an idea of what could be causing this.
kscudebec is offline   Reply With Quote
Old 02-05-2009, 08:37 PM   #2
Old School
Willie T's Avatar
Could be simply sawdust in the trigger area. The trigger switch, itself, is likely enclosed, but junk and gunk could be holding the trigger on. Before ripping into the handle to replace a possibly defective trigger, try blowing it all out in that area with an air hose while working the trigger on and off. (unplugged, of course)
Willie T
Old 02-05-2009, 09:27 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
good tip Willie you could also try an electronics parts cleaner try radio shack whats the make of your saw?
Tom Struble is offline   Reply With Quote
Old 02-06-2009, 05:12 AM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
Another nice addition to any table saw/miter saw/band saw is a foot switch like those used in sewing machines. I saw some on sale last week at Harbor Freight for $10-12.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-06-2009, 06:39 AM   #5
the Musigician
DangerMouse's Avatar
gotta disagree with you on this one willie, i just replaced the switch on my CM saw recently. the switch is sealed, and the handle is sealed pretty tight too. more than likely it needs a new switch. i ordered one from toolbarn.com for about 20 bux.
(be sure to check the wiring order on the new switch! the one they sent was wired different than the original!)
DM
Old 02-06-2009, 06:48 AM   #6
my hitachi slide compound switch not sealed cleaning worked for me
Old 02-06-2009, 06:59 AM   #7
the Musigician
i'm not saying cleaning it won't work, of course, that COULD be all it needs. but if you click it on and off a few times and it still does that, most likely it'll need a new switch, or keep plugging it in when you need it. if it won't move/click, then a buildup of gunk could be keeping it from shutting off, though i think it'd be easy to tell the difference. but i'm merely voicing my own experience. let us know what happens?
DM
Old 02-06-2009, 07:07 AM   #8
ageed DM
Old 02-06-2009, 08:00 AM   #9
the Musigician
heck, i'm HOPING i'm wrong on this one guys, it'd certainly be easier and cheaper for the OP! (you know me, cheap and easy... hehehehe)
but if he has to get a new switch, here's the difference i ran across with the new switch's wiring pattern. be sure to look closely!
DM
Tags
electric motor problems , miter saw problems
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Suitable Miter Saw stand for 10" Sliding Makita compound saw zappy Carpentry 3 07-16-2008 07:33 PM
Using Compound Miter Saw Loman43 Carpentry 12 01-01-2008 01:36 PM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 08:48 AM
