Comical Bench Grinder Kawasaki - Tools - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 04:12 PM   #1
OregonThe Shower me state
Turbogus's Avatar
Hi gang,
A few years back my best friend gave me a 'Kawasaki' 840109 6" Bench Grinder. I've never had a use for one in my 52 years but now that my wife and I have finally bought (buying) our first home I'm becoming a bit more domestic.
So I pull the thing out of the box and begin assembling, I immediately notice there are no light bulbs for the twin worklights, as metioned in the manual. Okay, so what amp/watt and size are they? metric, SAE, or Chinese Whitworth.
Next I'm mounting up the tool rests and, the bolts holding them to the wheel shield are too long and run into the sides of the wheels.
This was indeed a gift, and I know it's not Kawasaki Heavy Industries manufacturing these but I feel that if Kawi lends their name to these made in China bench grinders, they ought to monitor manufacturing practices. I ride an old Kaw Z1R turbo and I know Kawasaki is capable of excellent products, but these days even the Japanese are outsourcing. Pity that.
Turbogus is offline   Reply With Quote
Old 03-31-2014, 04:14 PM   #2
Rewards Points: 6,652
Probably standard Edison base bulbs. As for the bolts. Go to your local Ace Hardware or Harbor Freight and get the properly sized bolts.
Old 04-01-2014, 12:12 AM   #3
Rewards Points: 744
Harbor Freight carries hardware?
Seattle2k is offline   Reply With Quote
Old 04-01-2014, 07:49 AM   #4
r0ckstarr's Avatar
Rewards Points: 2,060
Yep. I recently picked up a 300pc assortment of various sized washers for under $3.00
r0ckstarr is offline   Reply With Quote
Old 04-01-2014, 08:41 AM   #5
Turbogus's Avatar
So I go down to the local Ace Hardware and in a long 40 ft nut, bolt and other hardware room there was no stock of 5/16ths bolts shorter than 1/2" in length. So got some washers to backspace until I find my cutoff wheel. Found some chandelier bulbs that'll fit the lights on this at least.
Old 04-01-2014, 11:39 AM   #6
You can cut the bolts with a hacksaw. You have to have a small file to fix the thread at the end.
Old 04-01-2014, 06:37 PM   #7
Rewards Points: 16
Maybe, Just maybe, you should not be using any power tools.
merlefrey is offline   Reply With Quote
Old 04-02-2014, 08:29 AM   #8
Turbogus's Avatar
Since my first job for this grinder will be for sharpening some edges, I next went looking for a 100 grit aluminum oxide wheel. None to be found in this consumer desert. Had to resport to online but found a Norton for $18 clams from sharpeningsupplies.com
Old 04-02-2014, 06:14 PM   #9
Harbor Freight, Ace Hardware, Lowe's, Home Depot, etc. Most people are resorting to buy stuff online. All due to the stores are seeing the light, that consumers are doing more shopping online.
Old 04-02-2014, 06:52 PM   #10
Turbogus's Avatar
That being said, but in the long run it isn't a good thing in my opinion.
Old 04-03-2014, 08:27 AM   #11
All of my shopping is done online for computer hardware, and most household goods. Add to that, clothing.
I find better deals shopping online, then I do going to the Brick & mortar stores.
Old 04-03-2014, 08:35 AM   #12
Turbogus's Avatar
That may be so, but as for me I support local businesses whenever I can.
Old 04-03-2014, 09:14 AM   #13
That is why I stated Ace Hardware. Locally owned, but does not always have everything you need. That is where the online sites come in handy.
I cannot get electronic parts locally, so I use partsexpress.com. Repair parts for appliances, I go to repairclinic.com. Nothing locally can match their prices, along with employees that care about their customers.
The only three chain restaurants we do are: Chilli's, TGIF, Domino's. Everything else is local or regional ownership.
Old 04-03-2014, 03:58 PM   #14
Turbogus's Avatar
Sorry if I stepped on toes here, I was only referring to these 'other people' as I'm sensitive myself to internet sales, given my vocation.
temporary mount for my bench grinder jasonreck71 Tools 4 02-03-2012 07:20 PM
Bench grinder Justins1171 Tools 3 01-30-2012 12:09 PM
Bench Grinder Justins1171 Tools 5 11-23-2011 08:21 PM
Good bench grinder junkcollector Tools 0 10-07-2010 07:29 PM
20 amp circuit required for new bench grinder?? sdyck Electrical 6 04-05-2009 03:25 PM
