Close Quarters Drill - Tools - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 08:36 PM   #1
In a little over my head
Rewards Points: 706
close quarters drill
So, in wiring up my new addition, I borrowed a Milwaukee close quarters drill to drill thu a few studs. Couldn't have done without it. Now, I gotta have one, even tho I may never need it again. So, $130 seems like too much. I'm not in a rush, so I'll just keep my eyes open at yard sales, pawn shops, refurbs, etc.
I know the Milwaukee will run a 3/4" spade bit thru 3 2xs. HF has one, but I have trouble pulling the trigger at HF. Dewalt makes a 90 degree. Not sure who else.
Any recomendations? Avoids? I'm not interested in cordless.
ratherbefishing is offline   Reply With Quote
Old 02-04-2012, 08:46 PM   #2
Rewards Points: 13,750
It's one of those tools that going to end up getting little use unless you do that kind of work everyday. I'd save my money to something else you would use far more.
I've drilled hundreds of holes with a reguler drill and a paddle bit before I bought my first right angle drill. Wires to not care if the holes an exact 90 deg.
My right angle drill gets used a coulple time a year, My Muliti Crafter ossilating saw gets used 4 or 5 times a week.
Old 02-04-2012, 09:28 PM   #3
I love RAD drills! I have a Hitachi 12 volt rt angle impact driver, a Bosch 1132vsr,a craftsman mini T and a Ryobi D 130 vrr angle drill! Plus my weakling 9.6 volt makita angle drill!
toolaholic is offline   Reply With Quote
Old 02-04-2012, 09:28 PM   #4
Rewards Points: 706
Joe, you make good sense. It's definitely a "get you out of a jam, now and then" tool. That's why I know I shouldn't spend much on it. With the right coupon, I could probably get the Harbor Freight model for $20 or so. But even $20 is money thrown away if it doesn't "get you out of a jam" and you end up throwing it off the ladder.
Old 02-05-2012, 06:35 AM   #5
Out of the ones I mentioned above the mini t has a great feel and good power! The ryobi is strong but bigger! I recently saw a mini t go for $11 plus shipping on eBay! It will easily handle 3/4 spade bits!
Old 02-06-2012, 05:56 AM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I don't use it very often but I'm happy with an old corded Makita 1/2" RAD that is essentially a much lighter version of the DA6301.
For Spade bits the latest (Feb/March 2012) issue of FH Magazine has a great shoot- out on more than twelve brands of 1" spade bits. The reviewer built a test rig to measure boring speed and bit cost vs bit longevity. His test results showed a huge improvement when the tests were run using a low 500 RPM drill vs a 2500 RPM Drill. The 500 RPM drill won hands down for speed and lower cost per hole.
The tests were all on 1/2", 6" long bits, drilling through 4-1/2" framing lumber.
The winner was the Bosch daredevil Bit.
e.g. :http://www.amazon.com/Bosch-DSB1013-...8528876&sr=1-2
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Jay 78 (02-06-2012)
Old 02-06-2012, 06:00 AM   #7
Learning Things Every Day
Jay 78's Avatar
For Spade bits the latest (Feb/March 2012) issue of FH Magazine has a great shoot- out on more than twelve brands of 1" spade bits. The reviewer built a test rig to measure boring speed and bit cost vs bit longevity. His test results showed a huge improvement when the tests were run using a low 500 RPM drill vs a 2500 Drill. The 500 RPM drill won hands down for speed and lower cost per hole.
The tests were all on 6" bits drilling through 4-1/2" framing lumber.
Thanks for the post. I've been in the market for a good set of spade bits.
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-06-2012, 08:12 AM   #8
raylo32's Avatar
Rewards Points: 1,286
I bought the Milwaukee corded RAD about 10 years ago for a project. I've only used it a few times since but when you need it, you need it. It is a great tool but if I was in the market for one now I'd probably go with one of the cheaper options available today (like HF) since it gets such intermittent use.
raylo32 is offline   Reply With Quote
Old 02-06-2012, 09:29 AM   #9
Rewards Points: 256
I bought a 90deg attachment for a drill. $20 or so. If I used it more often, I'd hate it, but for twice a year or so its great.:
michaelcherr is offline   Reply With Quote
Old 02-06-2012, 07:20 PM   #10
Check out CPO Outlets.com. They sell new and reconditioned tools at good prices. As for brand, go to www.mytoolstore.com/compare/cpdrill2.html and check out their reviews.
MNsawyergp is offline   Reply With Quote
drill 2.5" hole through 10" concrete hole diy001 Remodeling 7 01-17-2016 05:50 PM
Which would be the better drill to buy? Syii Gardan Tools 6 07-31-2011 11:38 AM
Looking to buy new Drill Track Tools 30 05-04-2011 03:55 PM
diamond core bit to drill a dryer vent through brick vote4Pedro Building & Construction 7 10-20-2010 08:23 PM
Best (easiest) way to drill into poured concrete wall Todd-sta Building & Construction 11 11-16-2008 03:57 PM
