Cleaning Set Plaster From Tools - Tools - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 10:35 AM   #1
Cleaning Set Plaster from Tools
Hi, just joined this great forum. Ive got some rasps that were used to grind off green plaster. The plaster set on them, not pratically impossible to clean all the little teeth with wire brush. Is there a chemical base or acid that would react with the plaster to chemically remove it from the tools?
Froissart is offline   Reply With Quote
Old 09-27-2010, 01:38 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
probably need to scrape or wire brush. if you find an acid that works, will prob damage tools too
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-27-2010, 03:13 PM   #3
yeah id have to say take a wire brush to it
JWilliams is offline   Reply With Quote
Old 09-27-2010, 09:03 PM   #4
I havent tried this myself yet, but they say windex with amonia will clean plaster off tools and good for mud dobbers nest too.
markos55 is offline   Reply With Quote
Old 09-27-2010, 11:14 PM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
That would be interesting if true. Those nest are hard to get rid of.
I wonder in vinegar would help get rid of the plaster. I've seen it used (soaking) to get concrete off of steel parts.
WirelessG is offline   Reply With Quote
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 05:30 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
need information regarding powered drain cleaning tools Pipe7000 Tools 1 10-18-2009 01:05 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
