Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-08-2009, 09:07 PM   #1
cleaning out expanding foam nozzles
i have several obvious gaps in my house that id like to fill with expanding foam. i dont expect that ill use anywhere near the whole can on the first go. instructions say to clean up unused material with acetone, but not much beyond that.
how do you clean out the nozzle so that the foam doesnt dry inside it?
anervoustwitch is offline   Reply With Quote
Old 07-08-2009, 09:26 PM   #2
I have gas!
Clutchcargo's Avatar
For Great Stuff, you need to use the entire can at once. Hilti brand has a reusable nozzle.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-08-2009, 09:50 PM   #3
I think most cans now have a tip where you can bend the straw back and seal it. I don't know how long it will keep, but it won't dry out right away.
jerryh3 is offline   Reply With Quote
Old 07-08-2009, 10:37 PM   #4
I set the can aside and give it a fresh squirt into a garbage can every 30 mins or so to keep it from setting up, that still doesn't give you more than one night with it though....
Unrelated but, the GREAT STUFF straws are REALLY easy to break... broke one yesterday just trying to pull it off the celophane packaging on the can, and then another one by tightening it too much... ugh i always have extra cans floating around and can never find a straw.
johnnyboy is offline   Reply With Quote
Old 07-10-2009, 02:43 PM   #5
gravity always wins
If I plan to save a can, I always blow the nozzle tube out with compressed air immediately and clean the can tip out with a cotton swab dipped in acetone. That seems to work for me.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
benjamincall (08-24-2010)
Old 07-14-2009, 11:52 PM   #6
If the foam has set up, you can use a length of 12 gauge wire to push the foam out of the straw. First you need to separate the straw from the trigger. It has a barbed end, and the straw should pull right off. The foam doesn't stick to the straw, so it should slide out in one piece. Clean the trigger the same way, re-assemble, then you can use the rest of the can.
Mthrboard is offline   Reply With Quote
The Following User Says Thank You to Mthrboard For This Useful Post:
Old 07-19-2009, 08:52 AM   #7
Or buy dap latex foam if it suits the application Much easier cleanup and better for reuse
Chemist1961 is offline   Reply With Quote
Old 08-10-2009, 07:30 AM   #8
DIY Hack
Mr Chips's Avatar
Easiest way is to remove the straw, turn the can upside down, point into an old cardboard box, and pull trigger for a couple seconds. Straw can be cleaned with acetone, or compressed air, or you can toss it and just use a piece of poly tubing next time. Hilti, Todal, Foam-o and others do make cans that take a reusable gun. the nice thing is you can use half a can, tighten up a screw on the gun and simply leave it for a day/week/month, then open up the screw and pick-up right where you left off. The downside is the guns ain't cheap, and once the foam does cure in them, they are pretty much imposible to salvage
Mr Chips is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Expanding foam insulation, where to find it in Nova Scotia? tankd0g Building & Construction 6 06-28-2010 05:33 PM
Expanding foam for recessed lighting? integlikewhoa Electrical 23 01-18-2010 10:58 PM
expanding foam flamability BigDogg77 Building & Construction 11 12-03-2008 11:48 AM
D-I-Y expanding foam insulation 4just1don Building & Construction 1 11-29-2008 11:36 PM
