Clean Oil Off Of Tools, Also Clean The Inside Of A Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 08:52 AM   #1
Clean oil off of tools, also clean the inside of a compressor
More specifically an oil-run air compressor.
I bought it used, very old. It's a bit rusty but the most important thing is that it's very grimy.
What is the best material to clean oil grime off of the compressor / motor / wires / belt / piston casing?
Also, the previous owner never seemed to clean the compressor inside and out. When i removed the drain plug, I had to poke the inside with a stick because the drain hole was plugged by all the oil grime.
Is there anyway to clean the interior of an air compressor?
capslock is offline   Reply With Quote
Old 12-23-2009, 11:36 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... Kerosine or whatever solvent you'd like to use...
Nope,... Not really, just drain it more often...
Rebuilding the compressor head should eliminate the excess oil problem...
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Bad compressor, and coil question... Undepelo HVAC 24 06-13-2008 01:28 AM
