-   Tools (http://www.diychatroom.com/f29/)
-   -   Clean oil off of tools, also clean the inside of a compressor (http://www.diychatroom.com/f29/clean-oil-off-tools-also-clean-inside-compressor-59815/)
capslock 12-23-2009 08:52 AM
More specifically an oil-run air compressor.
I bought it used, very old. It's a bit rusty but the most important thing is that it's very grimy.
What is the best material to clean oil grime off of the compressor / motor / wires / belt / piston casing?
Also, the previous owner never seemed to clean the compressor inside and out. When i removed the drain plug, I had to poke the inside with a stick because the drain hole was plugged by all the oil grime.
Is there anyway to clean the interior of an air compressor?
Bondo 12-23-2009 11:36 AM
Ayuh,... Kerosine or whatever solvent you'd like to use...
Nope,... Not really, just drain it more often...
Rebuilding the compressor head should eliminate the excess oil problem...
