Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 01-27-2006, 07:11 PM   #1
Question
circular saw rpm-is that the motor or blade rpm?
Circular saws have rpm rated on them, but I need to know if that is the blade or the motor? The project I am doing involves attaching a pulley to the motor and rpm's is absolutely important.
airpwr1@graceba.net is offline   Reply With Quote
Old 01-27-2006, 07:22 PM   #2
Contractor
What are you attempting to do? It sounds rather dangerous. Most circular saws are direct drive so that the two are the same. In the case of a worm drive, the motor RPM will be listed on the motor and the shaft RPM listed seperately on the motor plate or saw body.
Please, PLEASE don't tell me that you are attempting a DIY table saw.
Teetorbilt is offline   Reply With Quote
Old 01-27-2006, 10:01 PM   #3
robertcdf's Avatar
I would think that a circ saw motor RPM would be way to high to use for much other than a saw. Or maybe a fan. I would like to know what you are planing on making
robertcdf is offline   Reply With Quote
Old 01-27-2006, 10:55 PM   #4
with the blade taken off and saw housing mounted to bench, i am mounting a pulley to turn a alternator....alternator mid range rpm is 4500
Old 01-28-2006, 09:22 AM   #5
Contractor
Have you checked the alt. horsepower rating under load? It sounds as if you are assembling some Rube Goldberg contraption to accomplish........what?
Old 01-29-2006, 01:16 AM   #6
I know the HP needed....I am testing alt's
Old 01-30-2006, 01:45 AM   #7
Tired, Cold, and Damp
slickshift's Avatar
Unless it's a worm drive, the motor and the shaft and the blade rotate at the same RPMs
slickshift is offline   Reply With Quote
Old 01-30-2006, 10:23 PM   #8
Contractor
I'm still wondering why? What are you trying to accomplish?
Old 06-20-2009, 07:40 AM   #9
the Musigician
DangerMouse's Avatar
i guess we'll never know......
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-20-2009, 11:20 AM   #10
nap
You talking to me?
nap's Avatar
DM
has boredom set in DM? Not like you to respond to 3 year old threads.
Old 06-20-2009, 11:32 AM   #11
the Musigician
naah, i just found this thread when i was looking to build my own table saw from a circular saw and a few drywall screws to hold it to the table... just down the one side so it hangs there, you know.
kinda funny this never got resolved though.
DM
Old 06-20-2009, 12:52 PM   #12
Custom Cabinet Maker
Tho a really old post based on his screen name: IE Airpower, he should know that the rpm is the same as shaft speed, but increases dramatically as hou expand out to the "disc" that is rotating IE tip speeds on either props or saw blades.
skymaster is offline   Reply With Quote
Old 06-21-2009, 02:10 PM   #13
I did this when I was younger and into car stereos, but not with a circular saw. I used a 110 motor and a high output alternator to make a power convertor to power my amps out of the car for testing. I used different sized pulleys till I got the rpms right for the alternator.
As far as the table saw from a circular saw I also built one of those before I could afford the real thing. I used my router to make a spot for the base plate to recess in the table and used some screws counter sunk in the plate to attach it. I just used a homemade fence so it was kinda a pain to adjust but worked.
ponch37300 is offline   Reply With Quote
Old 06-28-2009, 07:28 PM   #14
Household Handyman
I noticed the old post also, but wanted to share this. When you are asking about the "speed" of a circular saw blade versus the "speed" of the circular saw motor, I am thinking a hand held circular saw. The speed, or RPM, of the motor and the blade are the same. NOW, if you are talking about a table saw, with direct drive, where the blade is directly attached to the motor of the table saw, it's still the same, RPM for RPM. A blade driven by a motor/pulley attachment is different and we'll get to that. Here is your problem, to me: No one mentioned Surface Speed in Minutes vs. RPM. A whole new ball game here. IF, note the IF, your motor is turning say 1000 RPM, and you have a 10" blade, the area where the mandrel of the motor attaches to the blade is going to turn 1000RPM's as the motor all day long, and yes the outside of the blade will be turning 1000 RPM's also. BUT, if you measure the circumference of the blade, a 10" blade will be app. 31.7" in circumference, which means that the outside of this blade will travel 31.7" with each revolution. Therefore with 1000 RPM's you will have 31,700" or app. 2641.6 Surface Feet per Minute (SPM). So, I hope you see that if you get into belt drives with different pulley diameters you will get different SPM's as you change pulley diameters. Having worked with manufacturing alternators I would highly recommend that if you are going to build a "test stand" you stick to that 4500 RPM range FOR THE ALTERNATOR. IF you are using a circular saw to do this, I highly do not recommend this approach, get you a motor that can be bench mounted. I won't tell you that we tested our units at two different speeds, low and high and what those RPM's were, it will scare the hell out of you. Thanks, David
when buying circular saw from Ebay be aware to ask KUIPORNG Tools 4 05-04-2007 10:29 AM
12 amp circular saw - how powerful is it? handbanana Tools 4 04-20-2007 11:04 AM
closing circular duct steve6 HVAC 7 02-22-2007 09:06 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
Using circular saw boxer1-2 Tools 9 12-28-2005 09:19 PM
