Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 10-13-2009, 01:10 PM   #1
LeviDIY's Avatar
Circular saw plung cut on the floor
Before I go ahead and do something not advised, I have a Craftsman powered circular saw, 7 1/8" blades. I have an underlayment I need to remove to get cabinets to sit correctly in kitchen floor. I have measured the total thickness at 1/8".
Can a circular saw blade depth be relied on for a cut this shallow? Underneath is concrete, so I don't really want to risk "cutting too deep."
LeviDIY is offline   Reply With Quote
Old 10-13-2009, 02:10 PM   #2
Not so new
12penny's Avatar
levi...sure. Set it and rip away. My concern would be why do you have to take up an 1/8" of floor?
12penny is offline   Reply With Quote
Old 10-13-2009, 02:15 PM   #3
LeviDIY's Avatar
Thanks for the reassurance
We are adding a pantry to a bank of cabinets where there was no pantry before. The flooring down right now ends at the edge of that existing run and is a layer of vinyl and under that a very very thin layer of what seems to be luan or some other very thingsubstrate glued/fastened onto the cement. I essentially wanted to cut the straight line with the circular saw and then try to scrape it all out cleanly.
Old 10-13-2009, 02:20 PM   #4
Not so new
12penny's Avatar
levi...pull up the vinyl first, check for nails and pull any in line with your cut. Luan is more like 3/16. Cut 1/8" and finish with sharp utility knife.
Old 10-13-2009, 02:23 PM   #5
LeviDIY's Avatar
Good call on the vinyl. Will do tonight and letcha know!
Also... what is a plung? Hahahaha... left the E off Sorry folks!
Tags
circular saw
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 07:23 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Attaching 3/4 Sturdy Floor with PL 400 jamiedolan Flooring 1 09-04-2008 10:15 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 10:53 AM
