Circular Saw Bevel - Tools - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 02:04 PM   #1
Rewards Points: 506
Circular saw bevel
It seems many new circular saws are offering a bevel capacity greater than 45 degrees. Excluding the process of gang cutting birdsmouths in rafters, where else would this feature be regularly applicable?
jlmran is offline   Reply With Quote
Old 12-11-2011, 07:41 PM   #2
Rewards Points: 12,886
It's really not of much use. Once in a great while an angle can be more then 45% or if you only want the to most outer tips to touch so there's no gap showing it's handy.
Old 12-11-2011, 08:47 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
if your just doing basic cuts you dont need this option. for framers its pretty much a neccesity. the combination of making cheek cuts on hip and valley rafters along with odd angle gable end studs and skewed joists on bays need this option
woodworkbykirk is offline   Reply With Quote
Old 12-12-2011, 08:20 AM   #4
Rewards Points: 506
Hip and rafter cheeks require >45 deg?
Edit: meant to say hip and valley...
Old 12-12-2011, 04:48 PM   #5
the angle of the cheek cut can vary depending on what the pitch of the roof is along with the one it ties into .. be it a unequal pitch roof or a gazebo
Double Bevel Miter Saw jburchill Tools 4 10-27-2011 11:48 PM
Circular saw? BigJimmy Building & Construction 4 03-29-2010 10:33 AM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
Considering a circular driveway proofer Landscaping & Lawn Care 1 06-20-2009 08:53 AM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
