-   Tools (http://www.diychatroom.com/f29/)
-   -   Circular saw bevel (http://www.diychatroom.com/f29/circular-saw-bevel-126281/)
jlmran 12-11-2011 01:04 PM
Circular saw bevel
It seems many new circular saws are offering a bevel capacity greater than 45 degrees. Excluding the process of gang cutting birdsmouths in rafters, where else would this feature be regularly applicable?
joecaption 12-11-2011 06:41 PM
It's really not of much use. Once in a great while an angle can be more then 45% or if you only want the to most outer tips to touch so there's no gap showing it's handy.
woodworkbykirk 12-11-2011 07:47 PM
if your just doing basic cuts you dont need this option. for framers its pretty much a neccesity. the combination of making cheek cuts on hip and valley rafters along with odd angle gable end studs and skewed joists on bays need this option
jlmran 12-12-2011 07:20 AM
Hip and rafter cheeks require >45 deg?
Edit: meant to say hip and valley...
woodworkbykirk 12-12-2011 03:48 PM
the angle of the cheek cut can vary depending on what the pitch of the roof is along with the one it ties into .. be it a unequal pitch roof or a gazebo
