Chop Saw Question, Cutting Base - Tools - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 12:06 PM   #1
Rewards Points: 50
Chop saw question, cutting base
When I set my chop saw to zero, it makes a nice cut, but when I set the miter to 45 it cuts the angle way outta square, as if on a bevel. What is going on, does this on both my saws...
tompatrick is offline   Reply With Quote
Old 02-05-2014, 12:24 PM   #2
Rewards Points: 14,026
Brand of Saw?
It needs to be check with a speed square in both direction and the indicator adjusted so it reads right.
PaliBob (02-06-2014)
Old 02-06-2014, 02:20 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by tompatrick View Post
....when I set the miter to 45 it cuts the angle way outta square, as if on a bevel....does this on both my saws...
What saws do you have?
Are they Compound Miter Saws?
http://www.thisoldhouse.com/toh/phot...419758,00.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-06-2014, 06:03 PM   #4
Rewards Points: 120
And what kind of bench or other support do you have? A bit of a rhetorical question, but be mindful that even with the saw itself dead on, the back needs to be high enough to prevent tipping and to allow for hollow backs, the table needs to be clear of chips and dust, and the stock needs to be adequately supported in order to prevent bending. It all seems obvious when you step back and look at it, but sometimes the simplest things are overlooked.
Acrylic Tub Lip/Tile Base Surround Question shawnsw Remodeling 1 03-26-2012 12:57 PM
New Furnace & Plenum Install Question rb404 HVAC 3 03-03-2012 11:29 AM
Question on oil base stain pakron General DIY Discussions 4 03-24-2010 07:42 PM
Cutting base around 3/4" corner bead Alan Carpentry 2 02-27-2010 02:32 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
