Champbel Hausfield Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 01:52 AM   #1
Champbel Hausfield compressor
Greetings.
I searched the forums before posting.
I got this compressor free
It runs untill it gets to 45lbs and then starts to cut out.
if i drain some pressure out it will run right.
it cuts out and will stall if i dont cut power.
i thought it might be the pressure switch so i got a new one and it does the same thing.
This is running on 120volt but the motor says 220volt is somthing screewey?
Tinner
I got nothing to do so i would like to fix this as a project
Tinner105 is offline   Reply With Quote
Old 02-01-2012, 02:32 AM   #2
I would wire it into 220v. I would guess that will solve your problem
My humble Man Blog
jasonreck71 is offline   Reply With Quote
Old 02-01-2012, 04:34 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Tinner
The motor is designed to run on 220. It tries to do its job even when you feed it half rations but as you increase its load with increasing pressure it craps out. I'd crap out too,if I was on half rations.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-01-2012, 07:29 PM   #4
Bingo
That was the problem.
When they built our houses here the left a spare box under the main elect panel.
I wired in a plug
wired a new cord from the compressor
Bingo...... filled it to 125psi and then cut off.
Thank you gentlemen
Tinner
Now i can get rid of that noisy vertical Craftsman compressor.
cambell hausfield compressor problem autobody man Appliances 1 06-05-2011 04:05 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 11:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
