-   Tools (http://www.diychatroom.com/f29/)
-   -   Champbel Hausfield compressor (http://www.diychatroom.com/f29/champbel-hausfield-compressor-132177/)
Tinner105 02-01-2012 12:52 AM
Greetings.
I searched the forums before posting.
I got this compressor free
It runs untill it gets to 45lbs and then starts to cut out.
if i drain some pressure out it will run right.
it cuts out and will stall if i dont cut power.
http://img69.imageshack.us/img69/7083/img0084gt.th.jpg
http://img194.imageshack.us/img194/2...g0082im.th.jpg
http://img560.imageshack.us/img560/5...g0083be.th.jpg
i thought it might be the pressure switch so i got a new one and it does the same thing.
This is running on 120volt but the motor says 220volt is somthing screewey?
Tinner
I got nothing to do so i would like to fix this as a project
jasonreck71 02-01-2012 01:32 AM
I would wire it into 220v. I would guess that will solve your problem
PaliBob 02-01-2012 03:34 AM
Tinner
The motor is designed to run on 220. It tries to do its job even when you feed it half rations but as you increase its load with increasing pressure it craps out. I'd crap out too,if I was on half rations.
Tinner105 02-01-2012 06:29 PM
Bingo
That was the problem.
When they built our houses here the left a spare box under the main elect panel.
I wired in a plug
wired a new cord from the compressor
Bingo...... filled it to 125psi and then cut off.
Thank you gentlemen
Tinner
Now i can get rid of that noisy vertical Craftsman compressor.
