Chalk Line Color - Tools - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 04:38 PM   #1
Rewards Points: 518
Chalk line color
Once a chalk line reel is empty, has anyone had success changing the color/type of chalk?
n0c7 is offline   Reply With Quote
Old 06-19-2013, 05:07 PM   #2
Registered User
Rewards Points: 526
Add another color, red is permanent...and some blacks.
Gary
Old 06-19-2013, 05:43 PM   #3
Framing Contractor
Rewards Points: 126
I ultimately end up with purple.
sixeightten is offline   Reply With Quote
Old 06-19-2013, 06:41 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
ive done it bu it takes time for the residual old chalk to slowly deminish.. depending on what color your switching to it can effect it.. i wouldnt switch from red to light purple since red is a permanent color and light purple is for temporary layout when having a color that doesnt stain is extremely important on say a carpeted floor or cedar deck
woodworkbykirk is online now   Reply With Quote
Condensate Drain Line Mystery flhvac HVAC 9 06-01-2013 11:08 PM
Chalk line for installing base cabinets noquacks Carpentry 15 03-01-2013 04:58 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Making a straight chalk line Krichton Building & Construction 11 03-19-2007 07:30 AM
