Chainsaw Repair - Cylinder Damage? - Tools - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 02:43 PM   #1
Chainsaw repair - cylinder damage?
My Dad had this Stihl 034 laying around collecting dust because someone told him a few years ago it was not worth fixing. I figured I had nothing to lose and would at least I would have a look.
Here is what I found so far. I took apart the cylinder and image 1 shows some scoring at the top of the cylinder near the spark plug.
Image 2 shows some scoring up the cylinder wall near exhaust. The piston looks to be in Ok shape although I will probably replace it.
Any suggestions on how to repair the cylinder or if this could be the cause of major problems?
Last edited by holmes55; 01-01-2012 at 03:02 PM. Reason: Would there be any way this is worth fixing?
holmes55 is offline   Reply With Quote
Old 01-01-2012, 03:05 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hone the cylinder and install oversized rings maybe. Don't know that is is worth all of that or if the parts are even available.
I was told the same thing about mine. Mine runs okay but is missing the safety yada yada so shops won't work on it and they say a replacement safety gizmo is not available. Hard to believe that a Stihl couldn't be made to live forever.
XXX
Old 01-01-2012, 05:29 PM   #3
DIY staff
Rewards Points: 7,174
If the parts aren't to pricey I'd fix it---My old faithful Dolmar has the same problems--But the parts are not available---
Old 01-01-2012, 06:23 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,... If the bottom end of the motor is Ok,...
Buy a piston, 'n cylinder replacement Kit....
Roof damage covered by homeowner's insurance frecks Roofing/Siding 3 11-18-2011 06:29 PM
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
Best Way to Smooth Out Ceiling Damage CaptChaos Building & Construction 18 08-11-2009 04:15 PM
