CFM Requirement For Brad Nailers? - Tools - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 11:02 AM   #1
Question
CFM requirement for brad nailers?
Found a good deal on this compressor at HF, $39.99 after coupon. The specs list 0.6 cfm at 90 psi and the title says that it's good for inflation, stapling, brad nailing, and air brushing. All of the buying guides that I've seen suggest that around 0.3-0.5 cfm is what you need for a brad nailer. However, all of the brad nailers that I've seen list around 4-5 cfm as the required air supply. I'm pretty sure it will work, but I'm having a hard time reconciling these two specifications. Does anyone know how to compare apples to apples with these?
Also, does anyone have any idea how this compressor would do with a 15 gauge finishing nailer or a framing nailer? The brad nailer would be what I use most, but it'd be nice to know if it would work for something needing more power.
webman3802 is offline   Reply With Quote
Old 06-16-2011, 11:34 AM   #2
4-5 cfm must be the bad spec. I have a 2 cylinder large compressor that only puts out 6 cfm. For a light duty cycle you should be ok.
jeffrow1 is offline   Reply With Quote
Old 06-16-2011, 11:53 AM   #3
Probably so. I found some finishing nailers at HF that only require 1.5 CFM, and even the framing nailers only listed 3.5 CFM. 4-5 seems very high for a brad nailer, so it's likely incorrect. Maybe they missed the decimal point?
Old 06-16-2011, 10:55 PM   #4
In a little over my head
Rewards Points: 706
Unless you're doing some kind of production work - and I can't imagine what that would be with a brad nailer - I think you'll be fine. You'll spend way more time thinking, clamping and scratching your head than you will shooting nails. I'd bet even a framing nailer won't tax that compressor, unless you're building pallets or running several nailers at the same time.
My compressor is mostly stationary, with a 30 gallon tank. I ran my framing nailer for several hours the other day (just me, not a crew) before I figured out the compressor wasn't even turned on.
Grinders, polishers, sprayers need big CFM. Most other tools are intermittent, and mostly run off the tank. Personally, I'd be more concerned about the fact that it's sold at Harbor Freight than the size. It's a disposable tool. By the time it wears out, you'll have a better idea of what you need.
ratherbefishing is offline   Reply With Quote
Tags
brad nailer , cfm , compressor
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 06:01 PM
Hitachi nailers???? mgarfield Tools 3 12-26-2009 03:39 PM
Question about Flooring nailers all7801158 Flooring 3 05-31-2009 12:00 PM
Question about Flooring nailers all7801158 Tools 1 05-27-2009 05:23 AM
Ceiling Nailers leted_82 Carpentry 2 04-13-2007 10:26 AM
