Central Pneumatic 2hp 8 Gallon Oil Lubricated Air Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 05-16-2015, 04:02 PM   #1
Rewards Points: 14
Central Pneumatic 2hp 8 gallon oil lubricated air compressor
I was wondering if I could use the Kobalt synthetic blend compressor oil ISO-100 instead of the recommended SAE 30 weight non detergent oil?
jaredmiller.dvm is offline   Reply With Quote
Old 05-16-2015, 04:18 PM   #2
Property Mgt/Maint
Rewards Points: 366
I sold industrial coolants and lubricants for the metalworking industry for 15 yrs. Older machinery that typically used mineral based oils were seldomly converted to synthetics. The reason is that some synthetics can soften older seals and cause leaks. Don't know for certain if it would be an issue for your compressor. Does the mfg have tech service hot line? Without a factory approval I would stick with the original factory recommendation. (IMO)
Yodaman is offline   Reply With Quote
Old 05-16-2015, 05:07 PM   #3
Rewards Points: 12,808
And save a ton of money by just using 30 weight oil.
Central air compressor kicking in but not staying on EMkid HVAC 2 05-10-2010 06:36 PM
New Central Air Compressor Problem Larsh HVAC 4 09-27-2009 09:29 PM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 11:50 AM
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 05:04 PM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 10:23 PM
