Cement mixer motor repair
HI,
PLEASE HELP ME IF YOU "CAN" THE MAKER OF THIS MOTOR IS POWER-FLO ON A CEMENT MIXER LTS40 AND IS 1/2 HP SINGLE PHASE WITH A 5 MFD START CAPACITOR. ALSO IS FITTED WITH A CURRENT COIL RELAY ONE MOTOR COIL WITH .5 OHMS RESISTANCE AND BLACK LEADS. THE OTHER COIL HAS THREE LEADS:- RED, GREEN, AND YELLOW WITH RESISTANCES AS FOLLOWS:- R/Y = 43.7 OHMS, R/G = 29.4 OHMS, G/y = 14.9 OHMS ONE 6 PIN ROCKER SWITCH. 5 MOTOR LEADS ALL TOGETHER MY PROBLEM? I NEED CIRCUIT DIAGRAM TO RE-WIRE TO THE MAINS.. |
Moved to Tools forum.
| All times are GMT -4. The time now is 05:25 AM. |
