Can't Get Radial Arm Saw To Bevel - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:43 PM   #16
Old School
Willie T's Avatar
About all I can say is Liquid Wrench or regular solvent and compressed air. Otherwise I dunno.
Maika'i pomaika'i !
Willie
Franšois Duc de La Rochefoucauld
Willie T
Old 09-06-2010, 11:19 PM   #17
Almost the same problem with the 113.198111! Need parts!
I too have a bevel problem with the bevel function on the 113.198111.
I opened mine up and found that the wedge bevel spring is cracked! Plastic!
I'm trying to replace it, but the part (815836) has been discontinued! What is the next step? Do I try to find a tool and die maker to make me one (out of metal??) Does anyone have the same saw/part lying around and I can buy the part??
Any help would be great!
rybenstein is offline   Reply With Quote
Old 05-26-2012, 10:50 AM   #18
Ever get it fixed?
Hi! I have what looks to be the exact same saw, same vintage, same problem. I doubt you'll check this 2+ year old post, but maybe. Ever get the bevel to work? Mine used to work but it's been a while.
Thanks.
Tom
em2323 is offline   Reply With Quote
Old 05-27-2012, 03:47 AM   #19
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Em, Sorry to say but redrover's profile shows her last activity date as 05-23-10.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-24-2012, 12:48 PM   #20
I gave up and picked up a miter saw and table saw. Will use this saw only for cross cuts, but probably won't hang on to it long. It's not made all that well. I wonder if more discontinued pieces will crack as quite a bit of this is just plastic.
Old 06-24-2012, 12:53 PM   #21
Tom Struble's Avatar
Rewards Points: 2,002
radial arms scare me
Tom Struble is offline   Reply With Quote
Old 06-26-2012, 02:53 AM   #22
Tool Geek
PaliBob's Avatar
ry, Make sure your Radial Saw is calibrated for 90░ Cuts.
Easiest way is with a framing Square
They are ~$7 at the HD
Disclaimer
& Stay Safe
.....Bob Lavery
Saw cuts inaccurate angles gma2rjc Carpentry 66 06-27-2009 05:25 PM
Sliding Miter Accurate On Bevel cut? linwin3000 Tools 11 02-26-2009 12:59 AM
Help With Radial Arm Saw EPMcGee Tools 3 03-13-2008 07:15 PM
Need a manual for my Radial arm saw dramsey64055 Tools 1 01-06-2008 11:18 AM
Radial Arm Saw Manual needed DAlnB Tools 6 11-27-2007 02:12 PM
