Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-05-2007, 08:08 PM   #1
Can't get blade off my saw
Help! I can't get the blade off my circular saw. I'm using the wrench that came with it, and I am turning it the right way, pushing down on the brake button as well. Any tricks?
Monty is offline   Reply With Quote
Old 06-05-2007, 08:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What way are you turning it...that makes you so sure that you are actually turning it in the right direction?
- Build Well -
Old 06-05-2007, 08:40 PM   #3
As gently as possible, wedge the shaft of a long screwdriver or similar device between one of the saw teeth and the foot plate of the saw. then turn in the direction that traps the screwdriver.
send_it_all is offline   Reply With Quote
Old 06-06-2007, 12:27 AM   #4
* I read my instruction manual.
Old 06-06-2007, 06:48 AM   #5
- Build Well -
Old 06-06-2007, 06:29 PM   #6
Custom Cabinet Maker
Atlantic: Sounds like it is a left handed thread If you have not gotten it loose by now try going opposite normal rotation.
They r a PIA until u get used to them.
JackM
skymaster is offline   Reply With Quote
Old 06-08-2007, 12:21 PM   #7
Hi Monty
If you have a pair of vice-grips try locking the jaw onto the blade. Make sure you are clear of the teeth. Turn your wrench as per owners manual, until the vice-grips contact the sole plate. If it still won't come off it may just be super tight, and you might need a bigger wrench, or possibly an impact gun.
Gerry
Gerry Kiernan is offline   Reply With Quote
Old 06-08-2007, 01:30 PM   #8
Heheh, better be sure which way to turn it!
Old 06-08-2007, 03:02 PM   #9
instruction manual normally won't be wrong.... I meant really really rare it will be wrong.... but make sure the manual is talking about left-hand/right-hand saw as the same one you are dealing with...
KUIPORNG is offline   Reply With Quote
Old 08-14-2007, 11:46 PM   #10
You are turning it the wrong way...to get the retaining nut off...it is turned Counter-Clockwise.
And DO NOT ...repeat...DO NOT use an impact device on it...
JGarth is offline   Reply With Quote
Old 08-15-2007, 06:40 AM   #11
It's been over two months, I think he's gotten it off by now...., in fact...read is earlier post on this thread...he did get it off....
- Build Well -
Old 08-20-2007, 12:29 PM   #12
All he said was that he read the instruction manual.
circular saw rpm-is that the motor or blade rpm? airpwr1@graceba.net Tools 13 06-28-2009 07:28 PM
What saw blade do you use to cut soffits? Malcolm Roofing 3 06-14-2007 12:48 PM
Miter saw blade ? VA Beach Trimmer Carpentry 5 04-14-2007 04:52 PM
Free Recip saw blade Brik Building & Construction 2 01-16-2007 05:40 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
