-   Tools (http://www.diychatroom.com/f29/)
-   -   Can't get blade off my saw (http://www.diychatroom.com/f29/cant-get-blade-off-my-saw-8964/)
Monty 06-05-2007 07:08 PM
Help! I can't get the blade off my circular saw. I'm using the wrench that came with it, and I am turning it the right way, pushing down on the brake button as well. Any tricks?
AtlanticWBConst. 06-05-2007 07:31 PM
What way are you turning it...that makes you so sure that you are actually turning it in the right direction?
send_it_all 06-05-2007 07:40 PM
As gently as possible, wedge the shaft of a long screwdriver or similar device between one of the saw teeth and the foot plate of the saw. then turn in the direction that traps the screwdriver.
Monty 06-05-2007 11:27 PM
* I read my instruction manual.
AtlanticWBConst. 06-06-2007 05:48 AM
:laughing:
skymaster 06-06-2007 05:29 PM
Atlantic: Sounds like it is a left handed thread:yes: If you have not gotten it loose by now try going opposite normal rotation.
They r a PIA until u get used to them.
JackM
Gerry Kiernan 06-08-2007 11:21 AM
Hi Monty
If you have a pair of vice-grips try locking the jaw onto the blade. Make sure you are clear of the teeth. Turn your wrench as per owners manual, until the vice-grips contact the sole plate. If it still won't come off it may just be super tight, and you might need a bigger wrench, or possibly an impact gun.
Gerry
boman47k 06-08-2007 12:30 PM
Heheh, better be sure which way to turn it! :)
KUIPORNG 06-08-2007 02:02 PM
instruction manual normally won't be wrong.... I meant really really rare it will be wrong.... but make sure the manual is talking about left-hand/right-hand saw as the same one you are dealing with...
JGarth 08-14-2007 10:46 PM
You are turning it the wrong way...to get the retaining nut off...it is turned Counter-Clockwise.
And DO NOT ...repeat...DO NOT use an impact device on it...
AtlanticWBConst. 08-15-2007 05:40 AM
It's been over two months, I think he's gotten it off by now....:laughing:, in fact...read is earlier post on this thread...he did get it off....
JGarth 08-20-2007 11:29 AM
All he said was that he read the instruction manual.
