Can You Run A Concrete Blade - Tools - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 08:53 AM   #1
Can you run a concrete blade
on a regular chain saw. I don't have a lot of concrete to cut, but there are times it would be handy to have your own concrete saw. I don't even know if it's possible to put a concrete blade on in place of the regular wood blade, but it would save me from a 40 mile round trip to rent a concrete saw every-time I needed one.
Does anyone have experience with this?
Thanks.
ole 66 is offline   Reply With Quote
Old 04-17-2009, 09:43 AM   #2
Concrete & Masonry
Rewards Points: 620
No, you cant. The ICS or Redsaws are entirely different from a normal chainsaw. They use an exclsive clutch, bar, chain system, & most importantly, a water lube system nothing like a wood chainsaw. Anyways, it would require a huge horsepower chainsaw to cut concrete. I believe our 12" ICS is 80cc.
jomama45 is offline   Reply With Quote
Old 04-17-2009, 01:34 PM   #3
Rewards Points: 26
They do make concrete blades for circular saws, 7 1/4". I have used them and they work if you only need to cut a couple inches thick.
ponch37300 is offline   Reply With Quote
Old 04-18-2009, 06:49 AM   #4
Thanks for your replies. I rented a saw last evening.
NOW I've got to find the "BOOK" that tells us how to get our wives to do this stuff!!!
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
