Can Someone Explain The Whole Drill/Driver Thing? Impact Driver As Well Please? - Tools - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 10:54 AM   #31
landfillwizard's Avatar
Rewards Points: 516
My neighbor has a Ryobi " drive cordless impact and just to see if it worked on my PU (dodge ram) and it torque the nuts up to 100# which is the proper torque. Now I have to get me one!
landfillwizard is offline   Reply With Quote
Old 03-30-2014, 12:00 PM   #32
Rewards Points: 212
Originally Posted by beenthere View Post
Not if the lug nut was tightened properly.
I wouldn't be so sure. For a lot of people "tightened properly" means hammering in it with an air impact wrench, which is usually way over tightened. If you took the rust off of your lugs with a wire brush and some elbow grease, then tightened the lug nuts to the manufacturers specs wih a torque wrench, you'd be surprised how easy they are to remove with just a lug wrench. The manufacturer's specs for my pickup are 78 ft lb, which isn't a lot of torque.
A Squared is offline   Reply With Quote
Old 03-30-2014, 12:24 PM   #33
Mold!! Let's kill it!
Rewards Points: 2,012
DeWalt lists several impact drivers (not impact Wrenches) up past 100 ft lbs. of torque even in the 12v models.
Old 03-30-2014, 12:42 PM   #34
Rewards Points: 516
Why I know it was 100# is because I checked it with my torque wrench. Which is the torque for my Dodge Ram.
Old 03-30-2014, 03:19 PM   #35
An old Tradesmen
Rewards Points: 7,802
There is only one properly. I didn't say tighten by opinion of tight enough.
So you think the impact shown in the OP is going to do 78 ft lbs.
Old 03-30-2014, 03:40 PM   #36
Rewards Points: 276
I was suprised to see how widely torque rating varied between vehicles. from 50lbs on a bentley to 200+ on hd trucks. Even same model chances vastly for different years.
http://www.discounttire.com/infoCent...eelTorque.html
The porter cable manufacture rates it at 1450 inch/pounds which is 120 foot/pounds.
JustinK is online now   Reply With Quote
Old 03-30-2014, 03:53 PM   #37
An old Tradesmen
okay, more then I thought it had.
Old 03-30-2014, 04:08 PM   #38
Rewards Points: 276
Its hard to believe a 1/4" shaft could ever transfer than much torque without snapping.
Old 03-30-2014, 11:20 PM   #39
Rewards Points: 212
Yep, sure do Just by coincidence, today was my biannual tire swapping day. WIth this thread in mind, I tried out my impact driver. It's noting special, an 18 V Dewalt DC825. FWIW, my impact driver has a lower torque rating than the one shown in the OP. It loosened the lugs pretty handily. Not as smartly as a good sized pneumatic impact wrench. I was also changing tires on a buddy's car. He subscribes more to the "tighter then down good" philoisophy, so no idea what they were torqued to, but they were tighter than the mine. My impact driver took those of also.
Old 03-31-2014, 04:13 AM   #40
An old Tradesmen
Thanks for the info.
Old 03-31-2014, 06:04 AM   #41
Rewards Points: 516
The one I use is " drive with a rating of 200 ft. lbs. It is 18V and it uses the same battery as my drill/driver.
Old 03-31-2014, 06:18 AM   #42
r0ckstarr's Avatar
Rewards Points: 2,060
Well, I'm sold. I'll be finding an 18V 1/2" Dewalt since I already have a bunch of 18V tools and batteries.
r0ckstarr is offline   Reply With Quote
Old 04-04-2014, 08:25 AM   #43
r0ckstarr's Avatar
I believe I am responsible for derailing this thread. Here's my attempt to get it back on track. When someone asked about the cordless impacts, they were referring to the 1/4" drive for screws and small bolts. Something that most people use a cordless drill for.
At the time, I just saw "impact" and the first thing I thought of was the pneumatic impact tools for working on cars. I didn't know the difference and asked if I could pull lugnuts off with one.
After doing some reading, I have found that this thread started out asking about Impact Drivers. What I was looking for was an Impact Wrench. There is a difference.
Impact drivers usually have a quick change bit on them, and the power it delivers is measured in in/lbs.
Impact wrenches come in standard ratchet sizes (3/8", 1/2", 3/4"). They create more torque, which is measured in ft/lbs.
Another way to think about it is this: The driver is for bolts. The wrench is for nuts. The thread was asking about bolts, and I was looking for nuts.
But, I did find what I was looking for.
I used it to rotate the tires on my truck. I had all 5 lugnuts off of the first wheel in the time it would have taken me to get 1 of them off with a 4-way, and they were torqued on with a pneumatic impact from the local tire shop. It took me longer to get the truck up on jack stands, than it did to rotate all 4 wheels. I look forward to wearing this tool out.
Now, my gf gets to learn how to change brakes on her truck. She goes through a set of pads twice as fast as I do.
The only thing that stopped me from getting the Ryobi was that the DeWalt was stronger.
Ryobi = 200 ft. lbs. of torque
DeWalt = 300 ft. lb. of torque
Old 04-04-2014, 06:00 PM   #44
A cordless impact driver uses 1/4" hex drive bits, while an impact wrench has a square drive and uses sockets. I've used a socket adapter in my impact driver to run some pretty hefty lag screws and it worked fine. I used it to change the wheels on my golf cart too, but I don't know if it's got the ooomf to loosen the lugs on my truck. That impact wrench is on my "need to own" list.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
r0ckstarr (04-04-2014)
Old 04-13-2014, 07:20 PM   #45
Rewards Points: 4,796
The 3 things they can engineer into 1 driver - the drill, the hammer drill, and the screw driver. The clutch (for the screw driver) is fairly easy to add. The drill is just having the clutch completely off. The hammer drill (for pounding bits into concrete) is usually a separate drill but it works with the flip of a button.
The impact driver is too different of a mechanism to fit into the save tool. But who knows? Maybe someday you'll see a single driver that can do all of that.
If you've ever tried to drive in a difficult screw with an impact driver, you'll never go back to using a regular drill driver to do it. It's just so powerful. It can take a screw and just go straight through the piece of wood without stopping. If your bit is long enough, you could drive it in a foot and right out the other side.
jeffnc is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Impact driver bits. Lowcountrydave Tools 8 03-21-2013 10:29 PM
Picked up my first impact driver ajtool Tools 8 10-31-2010 11:23 AM
I need an impact driver that goes in reverse tundrawolf Tools 5 03-02-2010 06:54 PM
