Can Large Drill Bits Be Used With Small Drill? - Tools - DIY Chatroom Home Improvement Forum
Poll: Skil or Bosch - Skil products are very affordable but do they have good quality?
Poll Options
Old 02-20-2014, 01:28 AM   #1
Can large drill bits be used with small drill?
Hi fellow diyers,
I am planning to buy an SDS-Plus drill.
1. Skil 2Kg Rotary Hammer 1715 - $65 - 550W, 20mm concrete.
(skil.co.in/tools/rotary-hammers-2kg-rotary-hammer-1715.html)
OR
2. Bosch Rotary Hammer GBH 2-28 DFV - $277 - 820W, 28mm concrete.
(bosch-pt.co.in/in/en/professional/power-tools/c131399/p106744/new-tools/gbh-2-28-dfv.html)
I need to use 1" (26mm wide, 400mm length/deep) SDS-Plus drill bits. Can I use it with the Skil? Will be used to drill masonry (not concrete).
I need to buy a large number of tools, hence I am sacrificing on tools that I will be using infrequently.
So if possible I would like to buy the Skil.
Since they all use the same sds-plus shank, I thought it might be. But I don't have any experience with this.
Could you please enlighten me?
music is offline   Reply With Quote
Old 02-20-2014, 02:18 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
In my opinion these two are about as far apart as it gets. If you want a hammer drill that will last go with the Bosch, if you just need one occasionally the Skil may work for you. If you do use a Bosch then use the Skil you will see the difference right off.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
PaliBob (02-20-2014), woodworkbykirk (02-20-2014)
Old 02-20-2014, 03:13 AM   #3
Hi Jim,
Thank you for replying.
Yes, they are very different. Thats because if I am getting the Bosch then I wanted to go for the best possible no holds barred.
But I have serious doubts whether the Bosch will be 4 times better, or atleast 2 times.
The thing that you said - use the Bosch, then the Skil and you will understand. That is the exact thing that was in my mind.Is there that big a difference. Could you kindly elaborate on that? It would help me a lot.
I am also afraid that I might run into situations that because of the Skil I may not be able to get a job done. I currently own an old 10mm chuck Black & Decker and it has frustrated me several times.
Or is the Skil good enough?
So sorry I am rambling....................
Old 02-20-2014, 05:35 AM   #4
Rewards Points: 5,974
I have the bosch have had it for years. use it not only to drill but tile removal, removing thin set, removing brick veneer from a house, you get the point. The thing is well made and when I pick it up I know it will work. Just my opinion but I think of Skil as being a DIY throwaway tool. Meaning not if but when it breaks you just get another one. Plus it's going to take power to drive a 1" bit in masonry.
The Following User Says Thank You to ToolSeeker For This Useful Post:
joecaption (02-20-2014)
Old 02-20-2014, 06:24 AM   #5
DIY staff
Rewards Points: 7,174
Definably forget the Skill--To light duty for a tool like that---Bosch makes a dependable hammer drill/demo---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 02-20-2014, 09:23 AM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
bosch, milwaukee or hitachi all make good hammer drills.. and rotary hammers
woodworkbykirk is online now   Reply With Quote
Old 02-20-2014, 07:19 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,370
Ayuh,.... As much as I hate to admit it,...
I've been buyin' Harbor Fright tools for stuff I use occasionally, insteada High Quality stuff, like my Everyday tools,..
I bought a bigger spline drive hammer drill 5 years ago,...
It's still hammerin' holes in concrete, 'n limestone today, just used it earlier this week,..
Last Fall,.. needed to hammer a dozen 3/8- 1/2" holes into limestone,...
The big drill was too big, 'n my Makita cordless, too small,...
Yep, went to the Harbor, bought a cheap SDS drill, 'n hammered the holes out,...
Cheap, 'n if I ever need it again, I got it,...
Old 02-20-2014, 07:33 PM   #8
DIY staff
I've got the big Harbor Freight SDS drill---so far so good---it paid for itself the first week----
drill bits; need good company jklingel Tools 0 03-11-2013 01:25 AM
Need help with selecting drill Zefrik Tools 31 07-27-2012 01:13 PM
Drill bits james2012 Building & Construction 3 07-07-2012 10:35 PM
best bit(s) to do electircal install rtoni Electrical 13 11-26-2007 08:24 AM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 10:17 PM
