Can I Cut Wood With The Dremel Metal Cutting Circle? - Tools - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 06:05 PM   #1
Can I cut wood with the Dremel Metal cutting circle?
I posted this in DIY repair General Discussion, but then I saw this location and think it might be more fitting:
Hi,
I'm very new to the rotary world. I have a Dremel 4000 and it's accessories, and I'm trying to trim about 1/4 in of wood off the bottom of a section of my cabinets. The section is about 3 feet long and 3/4 in thick. The bit advertised as a wood cutter seems only fit for very fine detailing or drilling holes. There is a metal cutting attachment which looks like it would accomplish the job much faster. It's circular and looks like you cut with its side. Can I use this or are there poor consequences? Thanks!
tmptplayer is offline   Reply With Quote
Old 10-04-2013, 06:36 PM   #2
DIY staff
Rewards Points: 7,174
That is the wrong tool for the job.----A multi-tool with a straight wood cutting bit will get you a nice neat cut.
I have a $35-- Harbor Freight one that works well----
If you post a picture of what you are going to cut,you will get the best suggestions---
GrayHair (08-07-2015)
Old 10-04-2013, 06:56 PM   #3
Thanks. I have pictures, but how do I upload them? It asks me for a URL.
Old 10-04-2013, 07:36 PM   #4
Bill Kearney
Rewards Points: 1,174
The rotary tools are not great for much more than just fine work. You will drive yourself crazy constantly going through the discs trying to get that done.
Depending on what you're trying to do using something like a Multi-max might be more successful.
http://www.dremel.com/en-us/Tools/Pa...spx?catid=2094
But there are many different kinds of specialty saws. Toe kick saws, undercut saws, jamb saws, and various attachment for things like a rotozip.
A picture of what you're trying to do would help. That or a better explanation.
wkearney99 is offline   Reply With Quote
Old 10-04-2013, 07:46 PM   #5
The essence of what I want to do is make a piece of wood 1/4 inch less long. The wood is about 3 feet wide, 3/4 in thick and attached to the bottom of a cabinet. I'd be glad to post pictures but I don't know how.
In coordinates, if Z = up and X = right... the current wood dimensions are (3ft, 3/4in, 3in) and i want it to trim 1/4 in off the z axis.
The wood is mounted to the bottom of a cabinet which is elevated about 6.5ft.
Old 10-04-2013, 08:02 PM   #6
Bill Kearney
What're you trying to do, remove enough to slide flooring under it or something?
What about using a flush cutting saw?
http://www.youtube.com/watch?feature...7Kcu2Nfc0#t=35
Or an oscillating saw:
Old 10-04-2013, 09:52 PM   #7
I bought a refrigerator about a 1/4 inch too tall for its space. The limiting factor is a cabinet over top of the refrigerator spot. The cabinets themselves aren't too close, but the face of the cabinet extends about 1.5 inches below the floor of the cabinet. I just want to trim this face about 1/4 in so that I can fit my fridge into the space.
Right now I'm drilling holes real close to each other then filing the wood down, but this is going extremely slow
Old 10-04-2013, 10:18 PM   #8
Bill Kearney
Cut to the chase, pun intended, and pickup a Multimax. They're pretty inexpensive and would likely make much quicker work of it... neater too.
Old 10-05-2013, 03:02 AM   #9
DIY staff
I usually make that cut with a router---and a straight cutting pattern bit--that has a roller bearing---I make guide blocks for the bearing to ride on---
This is neat but requires some experience with a router----
Old 10-05-2013, 04:11 PM   #10
Rewards Points: 267
Not sure what others do, but a lot of folks use various photo services, either their usual paid one or maybe a free account with some random name if they want to stay anonymous.
Flickr, Photobucket, etc. have free accounts. What you can do is upload pics there, Edit them to rotate them if necessary, maybe change size to something sensible for a forum post, etc. Usually the services have a button to click on to Share with an option to copy the URL. (Sometimes with several options for various sizes.) You'll want the one with the whole URL to make things easy. There might be one that says for Forums, but that will give you HTML code which might not work so just use the URL.
Scott
Scottg is offline   Reply With Quote
Old 10-05-2013, 04:26 PM   #11
Have you checked the leveling legs on the fridge to see if there's room to make the fridge a 1/4" less tall?
RoyalAcresRod is offline   Reply With Quote
Old 10-05-2013, 11:39 PM   #12
@Scott: Thanks- I didn't think of that
@RoyalAcresRod: Yes, the back feet are fixed unfortunately
@All: I ended up creating a notch in the trim with the dremel tool and a file then using a small battery powered saw to cut across. Thanks everyone for the help!
The Following User Says Thank You to tmptplayer For This Useful Post:
oh'mike (10-06-2013)
Old 10-06-2013, 05:21 AM   #13
Usually the back feet are adjusted from the FRONT by means of what appears to be a bolt under the grille at the bottom front.
Is this a used unit and you don't have the instructions? Get on the web and find the instructions. The rear wheels may look fixed, but probably aren't.
The manufacturer's site will have the instructions.
Old 10-06-2013, 06:31 PM   #14
Bill Kearney
I used my MultiMax and a router to do just what you're attempting. I had a new fridge that needed just 3/4" more clearance to get back into the old fridge cabinet. Trouble was the new flooring was laid (by the previous owners) over the old linoleum. This left about 7/8" drop between the tile and the old flooring in the cabinet. The fridge wheels made it impossible to slide it back in there. I used my router with a guide clamped onto the cabinet to do the bulk of the trimming. Then I cut the length back to the corners where my router wouldn't reach. Then I sanded everything smooth and used some touch-up to hide the raw edge. Lasted that way for 3 years without anyone noticing.
Old 08-07-2015, 04:56 AM   #15
Rewards Points: 2
This bit has a screw at end and a couple of washers used to connect the bit. Take screw out and pick the cutting disk that you want. Sandwich the dish between the washers and use the screw to anchor it in there. Put the end with the rod into the front. thanks
print man is offline   Reply With Quote
Metal Cutting Portable Bandsaw patsoman Tools 3 04-18-2012 08:40 PM
Metal Pergola products vs. wood. Andray Herron Building & Construction 1 03-20-2012 08:28 PM
Rotary Cutting tools (Dremel etc) ElectricMD Tools 5 02-15-2012 05:35 PM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 10:19 PM
cutting metal roofing ugabulldog Roofing/Siding 3 07-05-2008 12:25 PM
