Can Air Compressor Do That? - Tools - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 02:24 PM   #1
can air compressor do that?
First let me introduce myself.
I'm a small independent film maker in Maryland and I think I'm going to use some form of compressed air for a special effect and I thought that somebody on this forum could help me.
I need to know if an air compressor can deliver burst of air and not just constant flow!
More precisely, I need to simulate the exit wound created by a bullet coming out of the back of a head. Can a compressor blow out a piece of wig by delivering a quick burst of air?
Would it be better to use a CO2 cartridge? What tool use those cartridges?
Phil
phorland is offline   Reply With Quote
Old 09-07-2008, 02:36 PM   #2
the Musigician
DangerMouse's Avatar
easily, yes, and much safer than a co2, i should think.
DM
Old 09-07-2008, 02:39 PM   #3
So how do I deliver a burst of air with a compressor? Does it have something to do with the handle regulating the air?
Why do you think CO2 cartridges are not safe?
Old 09-07-2008, 03:36 PM   #4
Git
I would think a tire bead seater like this would be perfect for what you want
They are specially designed to dump the contacts of the tank REAL QUICK. Also, when I watch Mythbusters they have used similar devices - a series of air tanks controlled by one big dump valve to power their air cannons, etc
Git is offline   Reply With Quote
Old 09-07-2008, 04:31 PM   #5
the Musigician
if you already have or have access to a compressor, all you'd need is this from any compressor accessory kit, a length of flexy soft tubing to tape on back of head. lots of blood and a short burst is all you want, yes? the drawback to CO2 is the packaging allows a few tries, where as a compressor allows unlimited, and the CO2 may or may not have an attachment to do what you need, and trying to 'rig it up' yourself may lead to disasterous results.
DM
Last edited by DangerMouse; 09-07-2008 at 04:36 PM. Reason: sheesh, i need to proofread better....
