Campbell Hausfeld Wl510008 - Tools - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 06:04 PM   #1
i have problem with my compressor i changed the power switch its running but the gauge pressure of the tank is not going all the way barely the needle of the gauge moving half way what will be the issue?
Ralph
Ralph88 is offline   Reply With Quote
Old 08-09-2012, 08:47 PM   #2
Rewards Points: 83
Is the unit shutting off? Is the gauge broken? Too many variables.
Protocol. is offline   Reply With Quote
Old 08-09-2012, 09:23 PM   #3
Rewards Points: 13,712
Before you junk it check the line from the tank to the pressure switch.
Very common for them to leak.
Next I would check for leaks where the line goes into the head of the compressor. most often all that seals it is a cheap rubber O ring.
Next check the check valve, air should be going into the tank not out of it when it shuts off.
Last would be the reeds that are built into the head on the top of the compressor, they tend to break or crack when they get old.
If you go that far may as well pull off the cylinder and check the piston, rings and the walls of the cylinder.
I've seen the piston wear off on one side which cracks the rings and scores the cylinder walls.
Old 08-11-2012, 04:03 AM   #4
An old Tradesmen
Rewards Points: 7,328
Moved to tools forum.
older model campbell hausfeld air compressor value ??? nicholstwo General DIY Discussions 8 01-24-2012 01:44 PM
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 10:04 AM
Campbell hausfeld air compressor wont start Steve12 Tools 25 03-04-2011 08:17 PM
2 gallon air compressor combo - Campbell Hausfeld or Husky? whataboutj Tools 3 11-26-2010 02:31 PM
Bostitch VS Campbell Hausfeld nailers. Jim F Tools 4 04-25-2010 01:50 AM
