Campbell Hausfeld Good Or Bad? - Tools - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 12:33 AM   #1
Campbell hausfeld good or bad?
Usually the cheapest nailer or air compressor when i have looked. I plan on buying an air compressor and nailer/ stapler so i can put in moulding and baseboard and repair chairs and couches when the need comes up.
I was just wondering are they quality tools and will they last if i take good care of them or should i get a more expensive brand?
wnyrob is offline   Reply With Quote
Old 03-12-2012, 03:00 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 858
Funny you should ask that now.....
I have their nailer combo set (and compressor)....bought it back in 2006....used the dog crap out of the framing nailer to build a 2-story garage....now I'm building a 2-story addition....the 'spring' that keeps the nails tight in the magazine had an issue....ordered a new one...hopeing it gets here soon....PIA pushing on the nails by hand....
Otherwise, considering I don't use it for a living...I think it's a good nailer....compressor is noisy as hell....but typicaly of oilless types...
ddawg16 is online now   Reply With Quote
Old 03-12-2012, 03:28 AM   #3
Rewards Points: 626
If you take care of it and its for hobby work only you might get years out of it. Just drain the air out of the compressor after every time your done using it. If your gun needs requires oil use a good grade like senco. and it should last.
Nailbags is offline   Reply With Quote
Old 03-12-2012, 06:34 AM   #4
DIY staff
Rewards Points: 7,174
I agree,they are a good value for the money---Not pro quality but tough enough for your uses.
Porter Cable is another low priced gun that holds up well.
Campbell Hausfield compressors are good.
Old 03-12-2012, 02:18 PM   #5
In a little over my head
Rewards Points: 706
Gotta agree on the Porter Cable Nailers. Mine have given great service for "heavy" DIY use.
As for CH, I have one of their oiled 30gal compressors. It has worked fine for several years of intermitent use, and shows no signs of deterioration. No complaints.
OTOH, I tried setting it up with one of the CH "kits"; quick connects, air chuck (tire inflator), hose, tire pressure guage, blow gun.
The air chuck broke in half when it fell off the seat of my motorcycle.
The little stick with the numbers blew out of the tire pres gauge the FIRST time it was put on a tire.
The quick connects "disconnect" if you drag the hose thru the grass.
The blow gun leaked from day one, and the hose split within a year.
IOW, the campbell Haulfield kit was one of the worst thigs, anything, that I have ever bought.
But the compressor has worked great.
I'm guessing the nailer's somewhere in the middle.
But, pro or DIY, any tool that quits working or acts up when you are on a ladder is gonna make your day a lot worse.
BTW, treat yourself to at least one decent hose. I have a long, cheap PVC hose that will get from here to there (and twist and kink and pi$$ me off in the process). But I keep a nice rubber hose for the hose closest to the nail gun. My sanity and good nature is worth the $$.
ratherbefishing is offline   Reply With Quote
Old 03-12-2012, 07:47 PM   #6
Rewards Points: 512
i bought the combo kit a few years ago and the compressor blew up the first day i used it so i exchanged it for another one and its been running strong. i used the 18ga brad nailer for a couple years and it finally crapped out on me definitley not gonna last you forever but not bad for the weekender.
princelake is offline   Reply With Quote
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 09:26 PM
Campbell Hausfeld (electric) 1500psi pressure-washer problems Eric VB Landscaping & Lawn Care 0 06-12-2010 05:50 PM
Bostitch VS Campbell Hausfeld nailers. Jim F Tools 4 04-25-2010 02:50 AM
Where can I find good contractor and building material suppliers? geordge Green Home Improvement 3 03-11-2009 12:11 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
