Campbell Hausfeld Compressor Problem - Tools - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 11:26 AM   #1
Campbell Hausfeld compressor problem
Hi to all,
Done a google search and found this forum. Looks like a very interesting site.
My problem is I went out into my toolshed today to use my air compressor to blow out a few filters for my swifter vac.
I have a Campbell Hausfelf HL550100 max 125 psi compressor. It worked fine up until now. I noticed the air was all leaked out of it because the gauges were at 0.
I flicked the lever and it kicked in but noticed air was leaking from around the air flow adjuster valve when it got up to around 60 psi. I let it build up pressure until it was around 100 psi and then hit the lever to stop. The air continued to leak until i turned the control adjuster valve clockwise a bit to stop the air leak. I then turned the lever again and it built up pressure to about 120 psi but the cutout gauge seemed to be still trying to reach the cut out limit. each time i turn off the air escapes rapidly around the control valve.
It is possible that the control adjuster valve is faulty or maybe got moisture that formed ice causing this problem?
Before I could always adjust the control adjuster valve to 70psi to use my nail gun and then adjust back to 100 for normal operations.
Greatly appreciate any ideas on what I have to do.
Cheers
TheRock is offline   Reply With Quote
Old 03-12-2013, 01:14 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 990
Ayuh,... It could be Either,.... or Both....
Bondo is online now   Reply With Quote
Old 03-12-2013, 01:38 PM   #3
Thank you for replying. I wil have to remove the valve and bring it in the house for a couple days and test again.
cheers
Old 03-16-2013, 05:27 PM   #4
Hi again,
I was away for a few days so could not reply. The regulator was faluty so I bought a new one and the everything is working great again.
thanks for your help
cheers
Old 03-16-2013, 06:26 PM   #5
Bondo's Avatar
Rewards Points: 990
Originally Posted by TheRock View Post
Hi again,
cheers
Ayuh,.... Glad to hear that,...
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 10:04 AM
Campbell hausfeld air compressor wont start Steve12 Tools 25 03-04-2011 08:17 PM
2 gallon air compressor combo - Campbell Hausfeld or Husky? whataboutj Tools 3 11-26-2010 02:31 PM
CampBell Hausfeld Compressor problems Hexar Tools 13 11-23-2010 06:23 PM
Bostitch VS Campbell Hausfeld nailers. Jim F Tools 4 04-25-2010 01:50 AM
