Campbell Hausfeld 2030 Pressure Washer Problem - Tools - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 08:22 PM   #1
I have a Campbell Hausfeld 2030 Pressure Washer that is leaking water out of the valve beside the water hose hook up. I think the valve is called the Pressure Relief System Valve? It shoots out a stream of water 4 feet. I have taken the valve out and see nothing that looks out of the ordinary. Any ideas on what's going on and why water is shooting out of this valve. No joke, it shoots out of the valve atleast a 4 foot stream of water comes out of it?
68rs327 is offline   Reply With Quote
Old 10-22-2011, 10:51 AM   #2
Rewards Points: 48
At least some of them have a "sacrificial" bolt that sheers the head when the water inside the pump freezes.
Old 10-24-2011, 07:00 PM   #3
Household Handyman
Rewards Points: 1,408
The 2030 has a combination "pressure/thermal" relief valve. This will allow excess pressure (above the rated using pressure/which should be on the machine), and will allow water to "bleed off" if the pump is allowed to run too long without water actually moving through the pump. A lot of pressure washer pumps do not have adequate internal by-pass and will actually heat up the water within the pump cavity. This thermal relief valve will let water release to avoid high temp build-up. And--sometimes these type relief valves will just go bad. Without a pressure gauge and thermometer for testing, it's just a guess.
Old 11-09-2011, 11:04 AM   #4
Rewards Points: 150
Change the relief valve, two "bolts" hold it on. Where located, may be able to give you source for new PRV
CaptRandy is offline   Reply With Quote
Can I use a pressure washer in a basement? Red Squirrel Flooring 12 04-18-2011 03:54 PM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 09:16 PM
Has anyone ever used one of those garden hose pressure washer converter wands? jpearson311 Landscaping & Lawn Care 7 07-02-2010 06:05 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 11:41 AM
