Campbell Hauser Air Hammer - Tools - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 03:00 PM   #1
Handyman
Rewards Points: 512
HD has an air hammer, c/w 2 chisels for $30. Problem is, it needs a minimum 34 gal tank and an scfm of 6. This thing is handheld and would be perfect for punching vent holes, etc into concrete and brick. Problem is my compressor is only 5 gal with a 3.5 scfm. Does anybody know of a similar product more compatible.
canadaclub is offline   Reply With Quote
Old 04-19-2011, 06:07 PM   #2
DIY staff
Rewards Points: 7,174
Is that the pistol sized unit used by mechanics to knock off mufflers and such---or something bigger?
I've got a couple of the pistol sized ones and they work well enough with a dual tank contractors compressor.
Old 04-19-2011, 06:12 PM   #3
Handyman
Rewards Points: 512
Yeah, thats the one Mike..what sort of limitations are there?
Old 04-19-2011, 07:03 PM   #4
DIY staff
They are handy for chipping brick and finishing off a dryer vent hole through concrete,if you drilled a series of holes with a masonry bit.
Also useful for cutting duct work holes.
They need to be oiled regularly---about every 1/2 hour---Worth owning--I bought the first one to knock tile off of concrete---worked well by the dust blowing around was a mess----Mike----
Old 04-20-2011, 05:21 PM   #5
Rewards Points: 266
Just be sure not to overwork your compressor by using it too long, they all pretty much have a 50% duty cycle out of an hour. I have used many air tools from my portable oil lube twinstack compressor. My compressor puts out 4.2 CFM @90 PSI but using the air tools rated at about 4 CFM like the air hammer causes it to run continuously. Oil-less compressors will crap out quicker, despite of what anyone says.
junkcollector is offline   Reply With Quote
The Following 2 Users Say Thank You to junkcollector For This Useful Post:
canadaclub (04-20-2011), oh'mike (04-20-2011)
Old 04-26-2011, 04:46 AM   #6
Rewards Points: 212
"minimum" ratings like that are deceptive. there is no "minimum" but the lower you go on the tank size and compressor output scale, the less work you get out of your hammer.
If you wanted to use that hammer for a 20 second job, then 2 days later you wanted to do use it for another 20 seconds, you'd never know your compressor was "too small" If you wanted to use it full bore for an hour, you'd spend a lot of that hour waiting for your compressor to catch up.
A Squared is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 10:13 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 06:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 09:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
