Broken Airens Snow Blower - Tools - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 03:19 PM   #1
Angry
Broken airens snow blower
I have a Ariens 7hp snowblower model 724 with the tecumseh motor. The problem I have is that I can get it to start but it will not stay running especially if I put it in gear. I have drained the gas and put in fresh gas. I have pulled the carborator and cleaned it throughly with carb cleaner. I am running out of Ideas any one have any thoughts. I could use the help. It is snowing again outside.
pbud is offline   Reply With Quote
Old 12-31-2008, 09:48 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
sounds like it a fuel problem.Iwould remove the carb float bowl it probably
full of junk
Tom Struble is offline   Reply With Quote
Old 01-01-2009, 12:44 AM   #3
Safe, Most of the Time!!
brokenknee's Avatar
When you said "cleaned the carb" did you just pull the bowl and clean that or did you pull the carb off the machine take it apart and thoroughly clean and inspect everything?
To me it sounds like a carb/fuel issue, if you did rebuild the carb did you readjust the high and low speed idle screws. You must adjust the high speed first (the one on the side) start with 1 1/2 turns out and adjust from there. Low speed (the one on the bottom) start with 2 turns out and fine tune from there.
Also check all your lines to make sure they are not plugged. Don't forget your fuel tank, check to make sure no contaminants got in the tank. If you have a fuel filter replace it. While your at it you might as well replace the spark plug. At least pull it to make sure it is dry.
How long does it run? Does it backfire and shoot flames out of the exhaust? (possible valve problems)
Post back when you get it running, would like to know what the problem was.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-03-2009, 07:33 PM   #4
broken snow blower
I pulled the carboprator appart and I totally cleaned it. I did not do the rebuild kit yet. I did change the plug and now it will kick over if I spray some starting fluid in it but it still will not keep running. I do get fule from the tank through that line, because when I took it off the carb I had fule coming out of it. I did not touch the needle valve on the side but did reset the one on the bottom back to 2 turns as suggested. I did not see any kind of build up inthe carb but their was oxidationaround the bowl at the gasket. i cleaned that throughly and re installed.
The machune does not backfire or anything like that. It just doesnt seem to be getting fuel
Are there any tricks or suggestions in doing the rebuild kit.
Old 01-03-2009, 08:11 PM   #5
brokenknee's Avatar
http://www.cpdonline.com/695244a.pdf[/url]
http://www.cpdonline.com/692509.pdf[/url]
I am not a tech but maybe one of the two manuals listed above may help. You can save them as a pdf file if you like.
Here are a couple more for 2 cycle
http://www.cpdonline.com/692508.pdf
http://www.cpdonline.com/694782.pdf
and one for Tecumseh/Peerless Motion Driveline Transmissions and Differentials
http://www.cpdonline.com/691218.pdf
Snow Blower Pull doesn't have tension Camper147 Tools 17 02-03-2015 08:52 AM
Snow blower repair Gregoryj Appliances 4 12-21-2008 08:52 AM
Snow Blower Repair Labrador General DIY Discussions 5 06-03-2008 01:26 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
any tricks to re-string pull starter on snow blower? whwestman General DIY Discussions 4 01-14-2008 05:29 PM
