Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 11-11-2008, 06:19 PM   #1
briggs and straton engine
i have an old generator with a briggs and stanton 5 hp engine on it. its old but runs great. this morning i went to start it and on choke it runs great but when i shut the choke off it kills the engine, anybody have any ideas where to start to fix this, thanks spurrowl
spurrowl is offline   Reply With Quote
Old 11-12-2008, 12:09 AM   #2
You're not getting enough fuel. Fuel filter clogged, jets in carb clogged with vanish. If this is the old diaphram type carb it could be a bad diaphram. If it were a newer carb with electric ignition and an anti-backfire solenoid it could be low voltage to the solenoid
sv9779 is offline   Reply With Quote
Old 11-12-2008, 12:34 AM   #3
try you tube id be surprised if someone hasn't published something pertinent
kennzz05 is offline   Reply With Quote
Old 11-12-2008, 11:11 AM   #4
thanks i will try that, why did i not think of that spurrowl
briggs and straton engine trouble spurrowl Landscaping & Lawn Care 3 11-23-2008 09:25 AM
