Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-20-2012, 08:28 AM   #1
brass grommet wire terminators on electric motor
The electric motor of my 1950s era table saw has 1/4" brass grommet/donut terminators on the leads. I want to replace the plug and use the same sort of grommets because they would be less likely to vibrate loose than a U-shaped terminator. What tool is used to crimp the grommet around the wire, just a pair of grommet pliers? Any special tool that helps to hold the wire in place? Is this a special kind of grommet -- not the same as the kind used with fabric? Thanks
diy888 is offline   Reply With Quote
Installing Switch In Reversing AC Motor RetiredLE Electrical 13 02-01-2013 08:11 PM
How to replace condensor fan motor? twags HVAC 41 09-13-2012 07:05 PM
electric motor cross reference markdcoco Electrical 28 08-19-2011 01:46 AM
Wiring a replacement blower motor bodtchboy HVAC 17 08-11-2011 11:05 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
