Brass Fitting Broke Flush On Air Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 09:28 PM   #1
New House Newbie
Rewards Points: 95
Brass Fitting Broke Flush on Air Compressor
Using my air compressor the other day and a ladder fell on the output brass fitting that the air hose was hooked up to. Needless to say the fitting broke flush with the output on the regulator and I am wondering if there is a way to get the broken piece out. I cannot grab it with a pliers.
Brass Fitting Broke Flush on Air Compressor-fitting.jpg   Brass Fitting Broke Flush on Air Compressor-outlet.jpg   Brass Fitting Broke Flush on Air Compressor-outlet2.jpg
C_J_GO is offline   Reply With Quote
Old 08-02-2011, 10:03 PM   #2
would this nipple extractor work?
http://www.plumbersurplus.com/Prod/P...229167/Cat/655
or one of these
http://www.plumbersurplus.com/Cat/Pi...ctors/655/List
Old 08-02-2011, 10:24 PM   #3
New House Newbie
Rewards Points: 95
I will check locally here and see if I can find one instead of ordering online. Thank you very much for the idea!
Old 08-03-2011, 07:36 AM   #4
try a plumbing and heating supply
Old 08-03-2011, 10:46 PM   #5
New House Newbie
Rewards Points: 95
I picked up multiple size extractors today and it worked great! thanks again for the suggestion!
Old 08-04-2011, 10:29 AM   #6
glad it worked for you. now since you are prepared if it happens again it prob never will.
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 09:06 PM
Leak repair of Compressor (pipe fitting) redavalanche Tools 3 12-23-2010 07:37 PM
Brass fitting help Joe F Plumbing 3 09-22-2009 09:57 AM
How long to heat the brass fitting jgs1951 Plumbing 2 07-22-2009 09:19 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
