Brad Nailer - Tools - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 12:15 PM   #1
Rewards Points: 47
brad nailer
Which is best, the gas powered with the fuel cartridge and battery or an all battery, no fuel cartridge? thanx
jeffs55 is offline   Reply With Quote
Old 06-18-2013, 12:36 PM   #2
Rewards Points: 13,300
Why not one powered by an air compressor?
Would cost less then 1/2 as much, does the same job.
By far a brad nailer of all my air tools gets used the least.
About all it's good for is taking something in place while the glues drying.
Old 06-18-2013, 01:14 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,022
Another one for air.
If you are doing any volume of nailing, you will burn through those cartridges.
Old 06-18-2013, 01:31 PM   #4
Amateuralex's Avatar
Rewards Points: 270
The guys who installed my front door had the ryobi 18v version. Just a battery, no gas. Awesome. They said that they love it.
Amateuralex is offline   Reply With Quote
The Following User Says Thank You to Amateuralex For This Useful Post:
<*(((>< (06-19-2013)
Old 06-18-2013, 04:23 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the ryobi is brand new to the market and still not a proven product. its only been on hte market in the usa for maybe 4 months and just came out in canada this month.. im a tool tester on a two other sites , this nailer is suposed to be on its way to me from T.T.I who owns ryobi.. ... they also own rigid.. i know the rigid cordless nailer is less than reliable
as for battery vs gas. if your going to be using it regarly either will work. but if its only going to be used one day every few months or so go with the battery.. the gas cartridges expire over time as the gas slowly leaks out
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 06-19-2013, 01:26 AM   #6
Rewards Points: 47
I wouldn't use it more than once every little while. Not regularly at all. I have ruled out air compressor because of air line and restricted mobility. I would use this for the occasional trim install which is really every other blue moon. I just want one! I am going to look hard at the DeWalt battery only item, thanx.
Old 06-19-2013, 06:10 AM   #7
Davejss's Avatar
Rewards Points: 740
I've had a Senco cordless finish nailer for years. It works great. I love it for quick jobs where I don't want to drag out the compressor and hoses. Mine is an older one, just NiCad battery, no fuel cells and it works well on a full charge. With modern LiOn batteries I'm sure a new cordless brad nailer would be even better.
Davejss is offline   Reply With Quote
Old 06-19-2013, 10:10 AM   #8
Love for Construction
<*(((><'s Avatar
I have DeWalt's cordless 18v battery only 15g finish nailer and 16g brad nailer and I love them. They are great for doing quick installs of trim or for working high up on fascia trim or window trim. They are heavy, but do a great job. If I have a lot of trim to do, I would pull out my aircompressor and pneumatic guns, maybe.
It is nice to not be tripping over hearing the air compressor cycle why you work. I think the cordless nailers by DeWalt are great, and have been reliable.
-luke-
<*(((>< is offline   Reply With Quote
Old 06-19-2013, 02:06 PM   #9
the thing i dont like about the dewalts is the fact they are massive, their the same size a pneumatic framing gun.. not only that.. they perform just like every other dewalt nailer ive used.. roughly 15 of them.. they all jammed within the first hour of use
Old 06-19-2013, 03:06 PM   #10
<*(((><'s Avatar
Yes they are large and heavy. As far as your comment on them jamming, I've had only about one or two double nails feeding down, which are easily unjammed and I've used my two a lot, as well as have had coworkers who had them and have had good luck. The one wear item that does go out over time is the heavy band that helps cycle the flywheel it breaks, I've yet to have mine break, and would expect it to happen fairly soon on one of my guns. I guess the scorecard is one and one on the reliability of them. Just look at the reviews online, with that many people reviewing them well, I would say your the exception rather than the rule as many people have ran those guns I would presume at least an hour before writing the reviews, the same amount of time that all of your dewalts jammed on you, maybe you should avoid dewalts.
I'm not trying to say they would replace a pneumatic nailer in a production situation but they are a very nice and well built nail gun for a niche purpose. Handymen and remodelers running in and out of houses to do one room of crown or replace a damaged piece of trim, in my opinion the ability to grab it and go can't be beat.
The downsides to the dewalt as I see them are:
1. Large, although for a majority of trim applications this doesn't get in the way, especially if you get the angled version of them.
2. Heavy, they will wear you out using them for extended periods of time.
3. Expensive, like $250-350 for a gun, charger and battery.
I don't think I need to say the upsides, it is all tied to it's portability.
I just finished using my 15g on a hickory cabinet install and it would sink a 2" nail into 3" of hickory (nailing the adjoining cabinet faceframes together) just fine, not something I would have expected it to do.
-luke-
Old 06-19-2013, 03:14 PM   #11
<*(((><'s Avatar
I too have heard lots of people who have had problems with the ridgid cordless nailer, but I have no personal experiences with it. I would like to know what you experience with the ryobi cordless that just came out, I saw them at home depot and the price is really affordable for the average homeowner, much more reasonable then the dewalts price tag.
-luke-
Old 06-19-2013, 04:06 PM   #12
yah.. since most of ryobi`s stuff is geared to the homeowner i dont think the nailer would last too long for me even just for cleanups on trim jobs (cleanup= last few pieces of trim that need to go on after cabinets are installed and what not)
as for dewalt. im not a fan of their tools AT All.. i find them to be overhyped and under engineered, too often ive had to fiddle with their tools to try to get them to perform a cut im trying to do or fasten something.. i stick to bosch and makita for performance and accuracy
Old 06-20-2013, 12:04 AM   #13
WWBK, what would you know about tools????? Comon. Dewalt is the best tool out there!!!!
Every DW nail gun I have is sitting in storage. Glorified paperweights!!! The only DW I would get is the DW744. That is probably it. A friend has the 18ga cordless Dewalt. Absolutely garbage.
mknasa dad is offline   Reply With Quote
Old 06-20-2013, 09:11 AM   #14
Rewards Points: 5,974
My neighbor has the DeWalt had problems with it sinking the nail all the way, took it back and they gave him another one it did the same thing and jams were a problem.
Old 06-20-2013, 07:37 PM   #15
the 744 table saw is nice but thats about it.. i cant stand their mitre saws. among other things they make
Spark at end of brad nailer RK76 Tools 6 09-02-2012 11:21 AM
Brad Nailer for Fiber Cement siding? JtProCaddie Building & Construction 13 08-18-2012 02:14 AM
Do I need a Brad or Finish Nailer? atm Carpentry 13 03-10-2010 11:43 PM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 10:11 AM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 07:55 AM
