Bostich Nail Gun Seal Replacement - Tools - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 05:28 PM   #1
Rewards Points: 99
Bostich nail gun seal replacement
Trying to remove old trigger seal and contrary to the instructions included with the new seal, it will not just "POP" out. I've tried pulling and putting compressed air behind etc. it just won't budge.
Any suggestions?
Thank you
kirwinjd is offline   Reply With Quote
Old 11-07-2013, 08:24 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
After removing the pins that hold in the trigger, remove the trigger. You probably have that done already. Hold a folded up rag over the trigger valve so it doesn't go flying. You need about 110# of air pressure. Hook up the airline and it should pop right out. Only thing holding it in is a couple of O rings and gunk. If it doesn't come out right away, disconnect the airline and try some penetrating oil around the trigger valve then try the air again. Mine popped right out.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
kirwinjd (11-07-2013)
Old 11-07-2013, 10:16 PM   #3
Rewards Points: 99
Ok. I'll try oiling the old seal first. I did put a lot of compressed air behind it already but maybe the oil will finally move it.
Thank you very much
Old 11-08-2013, 02:06 PM   #4
Rewards Points: 99
Seal finally came out. Of course it would have come out a little faster had I only removed the pin that was holding it in first. The gun was so gunked up with crud, I couldn't see the pin until my second look this morning.
Old 11-08-2013, 07:57 PM   #5
Happens to the best of us. I usually take a second look if something's giving me a hard time coming apart.
Mike Hawkins
Old 11-08-2013, 09:50 PM   #6
Rewards Points: 99
Thanks mike. It came out exactly like you said-even faster. Didn't have a chance to put a rag over it before it shot out across the room
Replacement Windows & T1-11 Numb Building & Construction 7 01-30-2013 05:39 AM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
water line to toilet drips after toilet seal replacement J-lou Plumbing 1 10-20-2010 06:28 AM
Last minute Tips for Window Replacement? gmhammes Remodeling 20 08-17-2010 08:09 AM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
