10-15-2008, 03:09 PM
#1
bostich framing nailer-shoots doubles
I bought a 'used' bostich framing nailer and tried it out for the first time a couple days ago,,,sad to say it thinks it has to shoot a double nail every time.
is there an adjustment?
Also it shoots way deep in NEW soft wood,,,but when I nail into harder old wood in house it only goes HALF way in?? other than hammer persuation to finish it off,how do you set gun for BOTH species and applications??
10-15-2008, 03:40 PM
#2
Oldguy
The depth of the nail is set with the gun. If you are running sufficient air pressure (about 100 psi) the gun prolly needs a rebuild. As ffor the double shot, is the gun a sequential or bump fire?
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
10-15-2008, 07:46 PM
#3
I have gas!
I had the same problem when bumping the gun. For me, I think it's mainly my lack of experience using the nailer.
Some of the Bostitch nailers have a trigger option. My siding nailer came with two triggers; one for sequential and one for contact. If you don't have the other trigger you can probably buy one at the Bostitch site.
I tear things down and build them up.
10-16-2008, 02:06 AM
#4
I dont know cause I have no idea what the differnece is. It has to be depressed (the nose)to fire,but has a triger too. so what kind does that make it??
(I am always trying to learn)
10-16-2008, 02:09 AM
#5
IF I turn the air up to shoot thru the hard 2X's it goes right thru soft ones. So everytime I change from 2 softs,,, to one soft,one hard,,, to nailing on hard side first,,, I have to adjust the pressure??
10-16-2008, 07:42 AM
#6
Oldguy
Using a scrap piece of wood, pull the trigger and hold it down and 'bump' the nose of the gun against the wood. If it fires it is a bump mode gun. On a sequential fire gun, you must press the nose of the gun down fully and then pull the trigger to fire the gun.
10-16-2008, 08:22 AM
#7
I have gas!
4just, it may behoove you to download the manual for the gun from the Bostitch website.
http://www.bostitch.com/default.asp?...ft_tooldoc.htm
10-16-2008, 08:45 AM
#8
Sounds normal to me.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
