Bostich Air Stapler T50S4 Won't Fire - Tools - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 03:31 PM   #1
Bostich air stapler T50S4 won't fire
I have a lightly used T50S4 that won't fire. When aired up, and safety depressed, the trigger only makes a popping noise with no driver action. I have it apart, none of the parts appear to be broken or worn. I had it rebuilt once at a shop, and now it is back up to the same problems. Unfortunately I don't recall what repair the shop performed. Any suggestions, like buy Hitachi, etc.
packrod4wt is offline   Reply With Quote
Old 04-03-2011, 11:02 PM   #2
Rewards Points: 5,336
If you try another air gun, does it work?
Do you have an independent device to measure the air pressure coming out of the compressor?
Ron
Old 04-05-2011, 10:50 AM   #3
maybe putting some light oil in the gun may help....
fybountyhunter is offline   Reply With Quote
Old 04-05-2011, 10:57 AM   #4
It would need to be pneumatic tool oil.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
packrod4wt (04-05-2011)
Old 04-05-2011, 10:20 PM   #5
Thanks for the reply, air pressure was adequate, in fact I tried it with two different compressors. I'm just being cheap, don't want to invest $ in an older gun if the problem keeps repeating. It is a 16 ga., 1/2" crown construction stapler, most new construction staplers I believe have gone to 7/16" crown and the staples are cheaper as they are more common.
Old 04-05-2011, 10:27 PM   #6
Thanks Ron. I did oil the stapler (I used Senco gun oil, not sure if this is a problem), and when I took the gun apart all the sliding parts seemed to be well lubricated. I'll go lube it again and re-assemble it...I just don't want to throw parts ($) in it when I don't understand the problem yet.
Old 04-21-2011, 11:59 AM   #7
The trigger valve may need to be rebuilt with the correct internal o-ring (flat on one side and beveled on the other) if you can find one or just replace the entire valve with a new one. I tried rebuilding mine with a 25 cents o-ring because the OEM o-ring seal is not available. It stopped the leak but is exhibiting the same symptoms as yours. It looks like I will have to replace the entire valve (about $20).
dyutechie is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Do they make internet enabled fire detectors? Red Squirrel Safety 3 08-30-2010 03:39 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 07:55 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
