BOSCH SDS-MAX Rotary Hammer Leaking Oil Profusely - Tools - DIY Chatroom Home Improvement Forum
Old 08-18-2008, 05:31 PM   #1
Rewards Points: 1,062
Unhappy
BOSCH SDS-MAX rotary hammer leaking oil profusely
never seen anything like this from a power tool. i may be tripping but the thing also sounds like it is, well, less lubed than it ought to be. my guess is that some gasket blew that protects the crank shaft or something like that. i bought it used from a pawn shop.
Old 08-18-2008, 06:33 PM   #2
Custom Cabinet Maker
it needs to go back to bosch for rebuild. b4 u send it check out price then what new costs. Might be better off just buying new one
skymaster is offline   Reply With Quote
Old 08-21-2008, 02:23 PM   #3
www.toolsandmachinery.com
Bosch Rotary Hammer oil leak
When your Bosch Rotary Hammer gets too hot the grease will turn into oil. Try taking the front housing out and clean out the old oil and grease. Then re-grease Power Tool.
Good luck!
Don-
Last edited by AtlanticWBConst.; 09-01-2008 at 01:04 PM. Reason: Site Rules Violation: Advertising Link Removed
mmtools is offline   Reply With Quote
Old 08-21-2008, 02:39 PM   #4
I probably should have mentioned that I have repaired tools for 30 years so I may have sounded like it would be an easy job, but it actually could be a bear. Its a big Power Tool. You should have a local service center close by that could do that for you.
Don
Old 08-21-2008, 07:47 PM   #5
yes, i was heating it mercilessly (busting concrete for 10 min straight).
please help select a rotary hammer amakarevic Building & Construction 9 07-04-2008 01:58 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Makita versus bosch stuart23 Tools 5 11-15-2007 09:41 AM
