Bosch Sds Max 2-5/8" Core Bits - Tools - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 09:02 PM   #1
Bosch sds max 2-5/8" core bits
Does anyone know the pilot bit size on this bit? I've been looking online and I can't find anything.
Hvacwin is offline   Reply With Quote
Old 04-03-2013, 09:56 PM   #2
Concrete & Masonry
Rewards Points: 468
Most core bit's of this size use a 3/8" bit, but don't hold me to it..............
jomama45 is online now   Reply With Quote
Old 04-03-2013, 10:34 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
isnt it marked on the case for the bit?
woodworkbykirk is offline   Reply With Quote
Old 04-04-2013, 11:37 AM   #4
Unfortunately they don't and I bought this one with it missing the bit.
Old 04-04-2013, 09:51 PM   #5
Rewards Points: 996
ill msg one of the bosch reps i know.. he deals in their blades and bits department
Old 04-05-2013, 10:59 AM   #6
Concrete & Masonry
Rewards Points: 468
I would take it to a local professional tool supplier and see what they have for pilot bits. Many are 3/8" with a taper. If they have one that fits, it won't matter what brand the core bit is.............
Old 04-05-2013, 03:46 PM   #7
Rewards Points: 996
3/8"
Found that in a good review (and it rings true with my memory)
"I purchased two bits: 1 3/4 inch and 2-5/8 inch for plumbing purposes. We use these core bits nearly every day. The trick is to drill a 3/8" pilot hole completely through your work first. Then change to the core bit and let it do its work. Drill 3/4 of the way throughfirst, then finish from the other side. A perfectly clean and smooth hole with little mess every time. This bit has more teeth than most others and is built with better steel and has a thicker boby than any other brand. It cuts through common brick, hardened face brick, concrete and prestressed (Flexicore) almost effortlessly. And they last a long, long time. Definatley worth every penny many times over."
as per joe sainz. bosch accesories rep, he comes from a background in commercial concrete work
Old 04-06-2013, 10:07 AM   #8
Thank you everyone. I was able to locate an exact replacement from a new wholesaler in the area.
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 06:40 PM
Sound insulation: Changing interior hollow core door to solid core, or exterior door? aminus21 Building & Construction 1 03-10-2011 01:43 AM
Need soundproof: Changing interior hollow core door to solid core, or exterior door? aminus21 Remodeling 4 03-08-2011 03:19 PM
Question: Can I Install Pergo over Dri Core? Starlight Flooring 1 10-01-2010 09:05 PM
best bit(s) to do electircal install rtoni Electrical 13 11-26-2007 09:24 AM
