-   Tools (http://www.diychatroom.com/f29/)
-   -   Bosch sds max 2-5/8" core bits (http://www.diychatroom.com/f29/bosch-sds-max-2-5-8-core-bits-176222/)
Hvacwin 04-03-2013 08:02 PM
Does anyone know the pilot bit size on this bit? I've been looking online and I can't find anything.
jomama45 04-03-2013 08:56 PM
Most core bit's of this size use a 3/8" bit, but don't hold me to it..............:whistling2:
woodworkbykirk 04-03-2013 09:34 PM
isnt it marked on the case for the bit?
Hvacwin 04-04-2013 10:37 AM
Unfortunately they don't and I bought this one with it missing the bit.
woodworkbykirk 04-04-2013 08:51 PM
ill msg one of the bosch reps i know.. he deals in their blades and bits department
jomama45 04-05-2013 09:59 AM
I would take it to a local professional tool supplier and see what they have for pilot bits. Many are 3/8" with a taper. If they have one that fits, it won't matter what brand the core bit is.............
woodworkbykirk 04-05-2013 02:46 PM
3/8"
Found that in a good review (and it rings true with my memory)
"I purchased two bits: 1 3/4 inch and 2-5/8 inch for plumbing purposes. We use these core bits nearly every day. The trick is to drill a 3/8" pilot hole completely through your work first. Then change to the core bit and let it do its work. Drill 3/4 of the way throughfirst, then finish from the other side. A perfectly clean and smooth hole with little mess every time. This bit has more teeth than most others and is built with better steel and has a thicker boby than any other brand. It cuts through common brick, hardened face brick, concrete and prestressed (Flexicore) almost effortlessly. And they last a long, long time. Definatley worth every penny many times over."
as per joe sainz. bosch accesories rep, he comes from a background in commercial concrete work
Hvacwin 04-06-2013 09:07 AM
Thank you everyone. I was able to locate an exact replacement from a new wholesaler in the area.
