| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Begin a Crosscut with a Table Saw
by Expert Village
Hi! I’m Rob McMahon for Expert Village. Now, although ripping is primarily what you’ll do with your table saw, you can also perform cross cuts with a miter gage. This saw has one that's stowed on board. Remove our fence and set that right on... Read More »
Miter Saw Basics & Information
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating the basic functions of a miter saw. A miter saw allows you to make perfectly accurate straight miter and bevel cuts time and time again. A straight cut is a... Read More » Perhaps you have a piece of trim that you want flush with a cabinet. If it's square with the wall, you'll need to make a 90-degree miter saw cut to match the trim to the cabinet. Making a 90 degree miter saw cut is fairly straightforward as long as you... Read More »
How to Make Angle Cut With Table Saw
by Expert Village
As you can see this was the regular cut. I adjusted the angle of the blade for a miter cut and now we'll demonstrate how it does and how it's done. First thing first, always your safety glasses and I have to put the machine on, I'll be back in a moment... Read More »
How to Calibrate for a Square Using a Table Saw
by Expert Village
Hi! I’m Rob McMahon for Expert Village. One important thing for your table saw is to be sure that your blade is square. The best way to do that is to take a square, here’s a speed square. You can also use a combination square. I’m going... Read More »
