Blind Rivet Question - Tools - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 03:14 PM   #1
Rewards Points: 101
Blind rivet question
I have a bed where the headboard is loose because the end of a metal railing is loose. The end is attached to the main rail by two blind 1/4" rivets with 1/2" heads. It seems like 1/4" rivets are hard to find, would 3/16" aluminum rivets be sufficient for this application?
wvphysics is offline   Reply With Quote
Old 03-27-2011, 03:20 PM   #2
Rewards Points: 558
If you canít find them in your big box stores or local hardware stores check this site out: http://www.rivetsinstock.com/rivet30.htm and order them on line.
epson is offline   Reply With Quote
Old 03-27-2011, 04:17 PM   #3
fabrk8r
fabrk8r's Avatar
I'm familiar with the type of railing you are talking about. The rivets of which you speak are large solid rivets that are installed using a large rivet set or "buck bar" and a hammer. The rivets are still available from various sources such as McMaster-Carr or Fastenall.
Before you buy any new rivets you can try tightening the rivet by holding a heavy steel backer against the rivet and hammering it tight again. If that doesn't work the next easiest alternative is to drill the rivet out and install a bolt and nut, or do what I did and tack weld the frame rails to the grooved end stays.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
PaliBob (03-28-2011)
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Intersecting "W" valley at different angles question HanksLBZ Roofing/Siding 3 10-07-2008 09:22 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
