Blade For Jigsaw - Tools - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:56 PM   #1
Rewards Points: 211
Blade for jigsaw
What kind of blade should I get to cut through cement board? I need to cut a hole for a toilet.
gtothek is offline   Reply With Quote
Old 10-26-2011, 04:08 PM   #2
Civil Engineer
Rewards Points: 4,520
There are special cement board blades, I have one that actually has no teeth, just a sintered diamond surface. Works well. Wear a dust mask when you cut concrete, the dust is really bad for your lungs.
Old 10-26-2011, 04:27 PM   #3
Rewards Points: 211
would I be able to buy it at HD or Lowes? is it called some specific? or just a cement board blade?
Old 10-26-2011, 06:52 PM   #4
Civil Engineer
I bought mine at Lowes, no doubt they are available at any big box store or a well stocked hardware store. You will probably need a holesaw to get started with the cut, make sure you get a holesaw blade designed to cut concrete. You can also use a cement cutting drill to get started.
Old 10-26-2011, 07:15 PM   #5
DIY staff
Rewards Points: 7,174
Look in the blade section at any store---Remington carbide grit--
If you don't mind killing a couple of blades---a standard blade will cut it but will die young.
Old 10-27-2011, 06:32 AM   #6
Rewards Points: 211
I was going to drill a pilot hole to fit the jigsaw blade in with a drill. Any kind of special bit I need to buy as well?
Old 10-27-2011, 06:46 AM   #7
DIY staff
If this is Durrock---or a cement board like it---Just tap a hole into it with a hammer or screw driver--
Any old bit will go through it.
The hole doesn't have to be perfect--the thinset will take care of any raggidy edges.
In Durrock I use a circle cutter with a wheel (designed for drywall) --I cut a circle on both sides of the rock---slash an X into the circle with a knife---then gently tap the circle out with a hammer.
Takes less than 1 minute----
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
center flange on masonry blade tearing hughnohoo Tools 3 11-07-2010 07:39 PM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
IKEA Cabinets and a good saw blade (my experience) DIYatHome Kitchen & Bath Remodeling 0 12-13-2009 08:32 PM
