Black Oxide Drill Bits On Metal - Tools - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 11:04 PM   #1
Black oxide drill bits on metal
Hey there everyone, I've got an amateur question. I locked my bike with a u-lock, and now can't find the key. After searching for it for days, I'm giving up on the key. So now I need to drill through the lock. I have a DeWalt drill with black oxide drill bits--can I just take the drill to the key hole, or would that damage the bit since its metal on metal?
dasjambo is offline   Reply With Quote
Old 08-15-2011, 11:36 AM   #2
I think you would be much better off to Buy--beg--borrow a grinder with metal cutting wheel (disc). It could be burned off if you had the right torch. I would suspect that all componets of the lock would be hardened steel--if it is quality.
Some cheaper Chinese locks can be sawed with hacksaw
Giles is offline   Reply With Quote
Old 08-15-2011, 12:21 PM   #3
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree with Giles on the grinder. If you have to drill, put some 3 in oil on the lock before you start drilling to keep the bit cool. If the steel is hardened, you will likely dull the bit, but btwist bits are cheap.
WirelessG is offline   Reply With Quote
Metal framing, magnesium oxide (MgO) boards Quinian Building & Construction 2 02-03-2011 03:57 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Black & Decker Drill 18V is it worth it harold938 Tools 20 12-22-2007 08:22 AM
Black strips on wallboard mounted on metal studs regman Building & Construction 4 07-20-2007 10:07 PM
Black Metal Roof??? Goat66 Roofing/Siding 2 01-31-2007 10:58 AM
